833 decoding needed #1176197
02/10/12 08:04 PM
02/10/12 08:04 PM
Blenheim, Ontario Canada
BlenheimBoy Offline OP
Mopar 833 4 speed transmission. It is stamped C-13546 BA 29 79
what is this trans for?
yr?
thx
Bill
Re: 833 decoding needed [Re: BlenheimBoy] #1176198
02/10/12 08:06 PM
02/10/12 08:06 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That looks like a CASTING number from the main case , if so it's TOTALLY useless trying to tell what the trans is .
There should be a flat machined pad on the right side of the main case , there you will find STAMPED numbers ...
Re: 833 decoding needed [Re: BlenheimBoy] #1176199
02/10/12 08:21 PM
02/10/12 08:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '79 casting date makes it an OD 833.
Re: 833 decoding needed [Re: John_Kunkel] #1176200
02/10/12 08:38 PM
02/10/12 08:38 PM
JohnRR Offline
JohnRR  Offline
ok so not totally useless ..
OD trans is either an A/F body of truck van which will fit a B/E body ...
