Bellhousing Alignment #1176032
02/10/12 03:31 PM
02/10/12 03:31 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I put the bellhousing on and with a dial indacitor I am out .020 so I bought .07 offset dowels and set them both @ 2:00 O'clock
reset the dial indacaitor and here are my readings now and I anot sure if I am okay or not.
12:00 -.010 9:00 -0 6:00 +.08 3:00 -.04 with these readings I am not out more than +.04 or -.05 so I should be within specs?
Switched to the dark side...
Re: Bellhousing Alignment [Re: JSR1485] #1176033
02/10/12 03:57 PM
02/10/12 03:57 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You must be withthin .003 Total Indicator Readings for a good alignment. Tim
Re: Bellhousing Alignment [Re: astjp2] #1176034
02/10/12 07:10 PM
02/10/12 07:10 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Don't forget to check that the trans mounting surface is square to the block too. Run the dial indicatore along the machined flat face, where the trans bolts up. I had to use some very thin steel shims, on either side of the attaching bolts, between the block and scattershield to get mine squared up.
Re: Bellhousing Alignment [Re: jbc426] #1176035
02/10/12 10:05 PM
02/10/12 10:05 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I called Jammie Passon and he helped figure out what I was doing wrong, I was working off zero on the gauge. He said work off 30 and I did Much better readings Went from .030@ 12:00 to .034 @ 9:00 to .028 @ 6:00 to .032 @ 3:00
Thanks to Passon Performace
Well it is trans & all the rest of the parts. Top Notch guy and shop!
