Page 1 of 3 1 2 3
Anyone have a 69 lynch road car vin close to 9A217660 ? #1175850
02/10/12 09:59 AM
02/10/12 09:59 AM
WI Goodrich 54411 USA
Chaaargerb Offline OP
Anyone have a 69 lynch road car vin close to 9A217660?
I have a friend who is trying to find out the build date for his car. At this time he doesn't have the fender tag. Car is a 69 roadruner Thanks
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Chaaargerb] #1175851
02/10/12 10:42 AM
02/10/12 10:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would be end of January , more likely first week of February
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: JohnRR] #1175852
02/10/12 01:02 PM
02/10/12 01:02 PM
Just got 9A219655 Build date 1-31 any other vins?
I had two 69 chargers with build dates 1 day apart from the Hamtrack plant and there vins were about 2100 numbers apart. Did lynch road run that many cars a day? If so then the build date would be 1-29 or 1-30.
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Chaaargerb] #1175853
02/10/12 02:23 PM
02/10/12 02:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's a SCHEDULED day , nothing was etched in stone. My 69 Bee built at Lynch Rd was scheduled to be built 210 , it's original engine was assembled on 2/11 , obviously it didn't get built that day.
Does the car still have it's original engine ? also does it still have it's original K frame , there is a date stamped on it .
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: JohnRR] #1175854
02/10/12 03:22 PM
02/10/12 03:22 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
There may be out of normal SPD sequence coding for RR's in that VIN range. research continues.
The VIN falls into the range of other cars that have a very late January SPD.
Without factory documentation, it's impossible to know the original SPD.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: 69CoronetRT] #1175855
02/10/12 05:38 PM
02/10/12 05:38 PM
Does this vin fit in the norm? I understand the normal assy. line problems but the vins should come out on the tags in order. That for the most part is a machine stamping tags. After that who knows what happened.
Sorry I don't know all the terms but what is VONs?
What day do you think?
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Chaaargerb] #1175856
02/10/12 08:09 PM
02/10/12 08:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The tags do not come out of a machine in order , the vins are assigned when the car order is entered into the system . The cars do not go down the line one after the other .
The VON is the vehicle order numbers , without the fender tag , broadcast sheet , window sticker or dealer invoice ... or IBM card ... you'll never know what it is.
Is your FRIEND trying to make a fendertag ?
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: JohnRR] #1175857
02/10/12 08:54 PM
02/10/12 08:54 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've got a xxxxx9a222104. thought it was built 2/5/69, .
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Chaaargerb] #1175858
02/10/12 09:44 PM
02/10/12 09:44 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Yes, the VIN fits in the norm.
I think without factory documentation you'll never know the original SPD. If you are just looking for a general time frame to help find date coded parts, 'the last week of January' is probably close enough.
Seeking:
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: 69CoronetRT] #1175859
02/11/12 10:24 AM
02/11/12 10:24 AM
Do you have any vins with a build date from 1-29 to 1-31? If so how close are they? Do you have vins out of date order and if so how many and how far apart by the number of days?
That is about 1500 numbers off the 9A219655. Maybe there was a plant shut down or the tag machine was down a couple of days. I don't know. 69CoronetRT what do you think.
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Chaaargerb] #1175860
02/11/12 12:54 PM
02/11/12 12:54 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I think there may have been some non standard coding about that time but research continues.
I think if you are just trying to get a general SPD from the VIN, then 'end of January' is close enough to find other date coded parts.
I think if you are trying to find an exact SPD date to reproduce a fender tag, you'll need to have factory documents to know for absolute certainty as to what the SPD was.
Seeking:
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: 69CoronetRT] #1175861
02/11/12 01:42 PM
02/11/12 01:42 PM
Hey man do you work with the government? I don't understand what is so bad about sharing the info you have in your data base?
This would be great to know.
If the vins didn't come out of the machine in order then what number on the tag is consistent?
I know 2000 cars isn't a lot compared to how many were built but thats way more then I've seen.
I love to crunch numbers.
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: 69CoronetRT] #1175862
02/11/12 01:50 PM
02/11/12 01:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
... If you are just looking for a general time frame to help find date coded parts, 'the last week of January' is probably close enough.
The last week of January is all that is needed for date coded part.
There are people here that have registries that have allready flagged this VIN for not having a fender tag. And if you google seach forever 9A217660, perspective buyer will find this thread and know it does not have the original tag.
So Chaaargerb, is your friend trying to make a fender tag, yes or no??
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: autoxcuda] #1175863
02/11/12 01:53 PM
02/11/12 01:53 PM
dart1962_440 Offline
As a response to Chaaargerb, is the data base accessible at all? I have a St Louis car.
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: autoxcuda] #1175864
02/11/12 02:22 PM
02/11/12 02:22 PM
Okay if fender tag Nazi's have to know then yes I am trying to help the new owner make a reproduction tag for his car. If I was trying to hide anything then why would I use the correct VIN number? It's already flagged.So why not use the infomation you have to help make the repo tag as close to correct as possible?
So instead of sharing your knowlege were all going to talk about reproduction fender tags are the end of the world.
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Chaaargerb] #1175865
02/11/12 03:06 PM
02/11/12 03:06 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Fake tag is worse than none. If you aren't trying to fool someone why worry about having a fake tag made?
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: stumpy] #1175866
02/11/12 03:10 PM
02/11/12 03:10 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I've got one off a 67 Plymouth station wagon I can send him if he just wants a tag on the car.
Let me know!
Darren
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Chaaargerb] #1175867
02/11/12 04:03 PM
02/11/12 04:03 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Thanks for finally being honest.
Without documentation and since it's a bad tag pick any day in late January for an SPD, it doesn't matter.
Guess the gate, base and sequence number too. It doesn't matter.
Pick any VON. It doesn't matter.
Choose whichever 69 LR layout you want. It doesn't matter.
An accurate SPD is the least of your worries for reproducing a correct 69 LR tag.
Seeking:
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: Ludington1] #1175868
02/11/12 04:09 PM
02/11/12 04:09 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Let me know!
Put it on the 'vert and send it to me. I'll take it.
Seeking:
Re: Anyone have a 69 lynch road car vin close to 9A217660 ? [Re: 69CoronetRT] #1175869
02/11/12 04:10 PM
02/11/12 04:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Try one like this, you may get lucky;
Page 1 of 3 1 2 3
