Build sheets, fender tags for 2006 Charger R/T? #1175083
02/08/12 11:03 PM
02/08/12 11:03 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
Sorry for such a simple question, do late model mopars have anything like fender tags or broadcast sheets? I bought my first modern Chrysler in years (2006 R/T) and I am a total newbie - need schooling bad. Are there such things for LX bodies? If so, how do I decode?
Also, which site do people like better, lxforums or dodgecharger.com?
Re: Build sheets, fender tags for 2006 Charger R/T? [Re: Moparmaniacc] #1175084
02/09/12 10:33 PM
02/09/12 10:33 PM
Northern Virginia
Northern Virginia
This is what I have found out for 2006 Dodge:
2006 VIN DECODING INFORMATION
POSITION /INTERPRETATION /CODE = DESCRIPTION
1 /Country of Origin /1 = Manufactured by DaimlerChrysler Corporation. 2 = Manufactured by DaimlerChrysler Canada Inc. 3 = Manufactured by DaimlerChrysler De Mexico.
2 /Make /A = Chrysler (Hatchback)
B = Dodge (Sedan)
C = Chrysler (Sedan)
D = Dodge (Hatchback)
3 /Vehicle Type /3 = Passenger Car
4 = Multipurpose Passenger Vehicle Without Side Air Bags Sales Code (CGS) (Hatchback)
8 = Multipurpose Passenger Vehicle With Side Air Bags Sales Code (CGS) (Hatchback)
4 /Restraint System /H = Restraint System Air bags Front Next Generation Multi-Stage Sales Code (CG1) Witht Side Air Bags Sales Code (CGS)
J = Restraint System Air Bags Front Next Generation Multi Stage Sales Code (CG1) Without Side Air Bags Sales Code (CGS)
K = Restraint System Advanced Multistages Front Air Bags Sales Code (CG3) With Side Air Bags Sales Code (CGS)
L = Restraint System Advanced Multistage Front Air Bags Sales Code (CG3) With Side Air Bags Sales Code (CGS)
8= Multipurpose Passenger Vehicle With Side Air Bags Sales Code (CGS) (Hatchback)
Gross Vehicle Weight Rating E = 3001- 4000 lbs. (1361- 1814) KG (Hatchback)
F = 4001- 5000 lbs. (1815 - 2267) KG (Hatchback)
5 /Vehicle Line /A = 300 / 300C / SRT-8/ Charger (RWD) (LWD)
K = 300 / 300C (AWD) (LWD)
R = 300C/ SRT-8 (RWD) (RHD)
V = 300 Touring / Magnum (RWD)
Z = 300 Touring Magnum (AWD)
6 /Series /4 - H High Line
5 = P Premium
6 = S Sport
7 = X Special
B = 4 Speed Automatic, Sales Code (DG6)
B = 4 Speed Automatic VLP, Sales Code (DGV)
E = 5 Speed Automatic, Sales Code (DGJ)
7 /Body Style /3 = 4 Door Sedan Tall
7 = Hatchback Tall
8 /Engine /D = 3.0L V-6 cyl. Turbo Diesel Sales Code (EXL)
G = 3.5L V-6 cyl. High Output 24 Valve MPI Gasoline Sales Code (EGG)
H = 5.7L V-8 cyl. HEMI Multiple Displacement Gasoline Sales Code (EZB)
M = 3.0L V6 CYL 24 Valve Turbo Diesel Sales Code (EXL) (Hatchback)
R = 2.7L V6 Cyl. 24V DOHC Gasoline (MPI) Sales Code (EER)
T = 2.7L V6 CYL 24 ValveDOHC Gasoline MPI Sales Code (EER) (Hatchback)
V = 3.5l V6 CYL 24 Valve High Output Gasoline, Sales Code (EZB) (Hatchback)
W= 6.1L V8 CYL SRT HEMI Gasoline SMPI, Sales Code (ESF)
2 = 5.7L V8 CYL HEMI Multiple Displacement Gasoline Sales Code ( EZB) (Hatchback)
3 = 6.1L V8 CYL SRT HEMI Gasoline SMPI, Sales Code (ESF) (Hatchback)
9 /Check Digit /0 through 9 or X
10 /Model Year /6 = 2006
11 /Assembly Plant /H = Brampton Assembly
12 Through 17 Vehicle Build Sequence Six Digit Number Assigned By Assembly Plant
Re: Build sheets, fender tags for 2006 Charger R/T? [Re: Moparmaniacc] #1175085
02/09/12 11:23 PM
02/09/12 11:23 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
They still come loose in the the vehicle. On the dash or in the trunk and are usually tossed when PDIed.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
