Would a stretched chain have had timing retarded? #1174986
02/08/12 09:23 PM
02/08/12 09:23 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I want to make sure my car fires on the first go when I'm done reassembling it from my timing chain/cam change. My timing chain was ridiculously loose - I could almost pull it off with the gears still bolted in. I got my distributor back in with all of my marks on the inner shaft and body lined up after I got my new cam in the block and the new gears lined up.
Before I started, I had the initial timing set at about 11 degrees BTDC. Assuming my chain had the cam off by something like 8 degrees, should I twist my distributor a little in one direction or the other to rough my initial back to something that will start reliably?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1174987
02/08/12 09:32 PM
02/08/12 09:32 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well all I can say is first roll the motor over a few times to make sure you have the marks on the gears truly lined up right!
Re: Would a stretched chain have had timing retarded? [Re: Dodgem] #1174988
02/08/12 09:36 PM
02/08/12 09:36 PM
Eugene, Oregon
Eugene, Oregon
Done and done... believe me I'm not doing this job twice any time soon
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1174989
02/08/12 09:38 PM
02/08/12 09:38 PM
I'd suggest 10BTDC mild cam/15 wild cam. W a breaker bar come up on 10 or 15 easy keeping tension on the chain then twist the dist to set the magnet dead even w the tooth that places the vac adv in the correct general location and places the rotor on or near on the #1 plug wire cap terminal and note that vac adv will shift the rotor phasing from that point, CW (BB) and CCW on a small block EDIT that's 6 o'clock and 12 o'clock for #1 to be firing. Dot to dot #6 is firing
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1174990
02/08/12 09:39 PM
02/08/12 09:39 PM
GMP440 Offline
GMP440  Offline
Yes, a worn or stretched timing can cause timing to be retarded. Had that happen to my 68' Coronet back in 81'. One day on the way to work the car ran good. Went home from work, engine idled unusually low, could not get past 30mph. Next day car ran fine. Then the engine cut out in the street and could not get it to fire again. Got it home took the timing chain cover off and found the nylon teeth on the cam sprocket had worn out. The car only had 80 thousand miles on it. New timing chain and sprocket and was back in business again.
Just pop the distributer cap off and rotate the crank shaft one or two revolutions back and forth and see if the distributer rotor is moving at the same time as you are rotating the crank shaft.
Re: Would a stretched chain have had timing retarded? [Re: GMP440] #1174991
02/08/12 09:44 PM
02/08/12 09:44 PM
Eugene, Oregon
Eugene, Oregon
Good grief. It honestly hadn't occurred to me to statically roll the engine to 10 degrees and see where the distributor points... maybe this common sense deficiency my wife is on me about whenever I goof stuff up is a genuine problem!
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1174992
02/08/12 09:49 PM
02/08/12 09:49 PM
Actually you're doing great, it'll be up & running in no time. Yes you want it to fire off immed
Re: Would a stretched chain have had timing retarded? [Re: RapidRobert] #1174993
02/08/12 10:54 PM
02/08/12 10:54 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
My '69 Sport Satellite 318 had a stretched timing chain and messed me up big time until I figured out the problem. To this day I dont trust timing lights!
Re: Would a stretched chain have had timing retarded? [Re: Moparmaniacc] #1174994
02/09/12 12:36 AM
02/09/12 12:36 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Stretched chains make the cam timing events run late...
Put #1 cyl on the compression stroke and set the timing marks between 10 &15 degrees before top dead ctr. Line up the leading edge of the rotor to the leading edge of the #1 cap terminal and tighten up the clamp. fire away
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1174995
02/09/12 04:51 PM
02/09/12 04:51 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
When the Dots line up, the engine is set to fire on #6, NOT #1.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1174996
02/09/12 05:07 PM
02/09/12 05:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'll ask the really STUPID question since it seems everyone before me is AFRAID to ask it ...
If you aren't doing it again anytime soon WHY are you reusing an obviously spent timing chain ????
If it is the original timing chain it is an Alum gear that WAS plastic coated , if the chain was that loose the plastic has fallen off , it's going to jump a tooth and you will bend valves ...
Re: Would a stretched chain have had timing retarded? [Re: JohnRR] #1174997
02/09/12 07:38 PM
02/09/12 07:38 PM
Eugene, Oregon
Eugene, Oregon
No no, you misunderstood my question. I'm not reusing the chain. I marked my distributor position before I pulled it out to change out my camshaft and old timing chain/gears. Since the old timing chain was so stretched and not keeping the cam and distributor in proper phase with the crank, I was wondering if my marks would not be accurate for where the timing will actually be after installing a new tight chain and gear set, i.e. if it would have too little advance due to being marked based off of the old chain's positioning.
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1174998
02/09/12 07:43 PM
02/09/12 07:43 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Right you are starting over. Just find top dead center and point the rotor at the number one tower on the cap . Done.
I have mechanical Aptitude.
I can screw up anything.
Re: Would a stretched chain have had timing retarded? [Re: bboogieart] #1174999
02/09/12 08:14 PM
02/09/12 08:14 PM
Eugene, Oregon
Eugene, Oregon
Yep I got that. This is my first time doing this sort of thing on a V8, sometimes I ask the dumb questions rather than ASSume if I'm not sure.
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1175000
02/09/12 08:15 PM
02/09/12 08:15 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Only dumb question is the one you don't ask.
Re: Would a stretched chain have had timing retarded? [Re: Secret Chimp] #1175001
02/09/12 09:58 PM
02/09/12 09:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's why they make timing lights ... you have one correct ?
You should be close enough as long as you don't install it 180 out .
Re: Would a stretched chain have had timing retarded? [Re: Moparmaniacc] #1175002
02/09/12 10:34 PM
02/09/12 10:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What is it you dont like about timing lights. They only tell you when the plug fires that you have it on. If you have timing on 10 BTDC and the chain slacks 10 degrees then the dist will be retarded also since the cam drives it and the timing would be at 0 instead of 10 BTDC. I dont get what you are blaming the timing lite for ? Ron
