Intake manifold heater hose fitting #1174814
02/08/12 07:05 PM
02/08/12 07:05 PM
alberta
Publicbottle Offline OP
alberta
Hey everyone,
Just something that got me thinking. In regards to dis-similar metal corrosion, what material should the fitting be that threads into the (aluminum)intake maifold going to the heater core?
Brass, stainless steel? carbon steel? of course aluminum would be ideal.... i guess a person could make their own from alumin pipe stock..i couldnt see any alumn fittings available in my industrial catalogue.
Whats everyone using here?
Re: Intake manifold heater hose fitting [Re: Publicbottle] #1174815
02/08/12 07:37 PM
02/08/12 07:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
factory used steel. You however may use whatever is your favorite alloy
I am truckless..
Re: Intake manifold heater hose fitting [Re: Publicbottle] #1174816
02/08/12 08:43 PM
02/08/12 08:43 PM
Cast iron pipe from the hardware store w the threads smoothed a bit/2 hose clamps. For my alum rad I added a zinc anode (they're cheap ~$15 iirc) but yes it would take care of that too.
Re: Intake manifold heater hose fitting [Re: Publicbottle] #1174817
02/09/12 12:08 AM
02/09/12 12:08 AM
AndyF Offline
AndyF  Offline
I assume this is for a small block? I have a SB aluminum fitting in my product line. It is a new product so it isn't on my website yet.
Re: Intake manifold heater hose fitting [Re: Publicbottle] #1174818
02/09/12 03:57 AM
02/09/12 03:57 AM
Iowa
dsp Offline
dsp  Offline
Iowa
You raise a good question. I have a 1992 Shivvy Silverado that the factory heater hose connector corroded and broke off. The intake is cast iron and the fitting appears to be potmetal. Electrolysis caused the potmetal fitting to literally crumble and break off the manifold. I thought the same thing - dissimilar metals with an electrolyte (coolant) equals trouble.
Re: Intake manifold heater hose fitting [Re: dsp] #1174819
02/09/12 09:56 AM
02/09/12 09:56 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The chevy easy-corrode pot metal nipples broke alot and they were screwed into aluminum intakes. The parts department switched to all steel nipples as soon as these things were coming in everyday. The 2.8, 3.1 and 3.4 engines as well. Most of us had a quality pipe tap in our boxes too.
