Re: which year one engine harness is best ?
[Re: wesgtx440]
#1174734
02/09/12 11:02 AM
02/09/12 11:02 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
Welcome to Moparts, I am fairly new myself.
I believe the harness that is for electronic ignition is set up for a 4 prong ballast resistor. It is up to you but if it were me I would go with the stock harness and make the mods to it.
A member bought a YO engine harness for his 72 Satellite for a 440 and got it for Electronic ignition and I am 99% sure it didn't come setup for a 4 prong ballast .
[Re: JohnRR]
#1174735
02/09/12 11:17 AM
02/09/12 11:17 AM
Posts: 21,492 It's a dry heat
gtx6970
It's a dry heat
John, The electronic conversion M+H harness I used in the Cuda did indeed have the wiring plugs for a 4 prong ballast, and I don't remember if the ECU plug was wired for a 4 or 5 wire unit !!!
[Re: gtx6970]
#1174737
02/09/12 11:27 AM
02/09/12 11:27 AM
JohnRR
I'll have to look at it then I only saw the harness in the box ...
