Throttle cable clamp #1173629
02/07/12 12:40 AM
02/07/12 12:40 AM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I found a like new Thermoquad and want to try it on my 400 with Edelbrock Performer. Problem is, the throttle cable needs to be clamped in a much different place than with the Holley. See the pic. It's about 2 inches to the side and about 1 inch above where the existing throttle cable bracket is. Anything temporary I can rig up just to try this carb out?
Re: Throttle cable clamp [Re: Moparmaniacc] #1173630
02/07/12 02:10 AM
02/07/12 02:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The thermoquad used a different throttle cable bracket , you will have to put the cable in the clamp you have an make a link to extend the cable end to the carb or find the 72 up BB throttle bracket.
