How do I calculate final gear ratio? #1173560
02/06/12 11:35 PM
02/06/12 11:35 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
F70/14 tires have a diameter of 24.6 inches. That tire diameter gives me the factory 3:23 ratio.
I am currently running a 3:23 gear with a 28 inch diameter tire. How do I calculate my final gear ratio?
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173561
02/07/12 12:00 AM
02/07/12 12:00 AM
Orleans, Ontario
Orleans, Ontario
I found this equation which answers my question:
http://www.4lo.com/calc/geartire.php
Which gives me a final gear ratio of 2.84.
(28/24.6)x3.23 = 2.84
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173562
02/07/12 01:04 AM
02/07/12 01:04 AM
Dude, the final gear ratio remains the same until you change the rear gear ratio What are you trying to find out, engine RPM lost at a steady tire speed, or distant traveled with the taller tires for the same engine RPM or what?
Re: How do I calculate final gear ratio? [Re: Cab_Burge] #1173563
02/07/12 01:11 AM
02/07/12 01:11 AM
Orleans, Ontario
Orleans, Ontario
I was trying to find out what the actual gearing is with a 3.23 gear and 28 inch tires. Since the F70/14s (24.6 inch diameter) that came stock from the factory are smaller in diameter than my 28 inch tires, the final gear ratio on the road has to be higher than 3.23. I now know that it's equivalent to a 2.84 gear.
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173564
02/07/12 01:14 AM
02/07/12 01:14 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That doesn't make it equal to a 2.84 gear. It may make it equivalent to a 2.84 gear with 28" tires but that info isn't terrible useful because most of us pick a tire size and gear around it. I find this to be more useful and entertaining:
http://vexer.com/automotive-tools/speed-rpm-calculator
Re: How do I calculate final gear ratio? [Re: DaytonaTurbo] #1173565
02/07/12 01:20 AM
02/07/12 01:20 AM
Orleans, Ontario
Orleans, Ontario
I'm not trying to match tires and gears!!
It's a matter of curiosity. I just wanted to know what my final gear ratio is with a 3.23 gear and 28 inch diameter tires. A 3.23 gear with 28 inch diameter tires is equivalent to a 2.84 gear where the tires meet the road. A larger diameter tire will produce a higher gear on the road surface. It has to. It's simple mathematics. That's why cruising at 2500rpm with a 28 inch tire will give you a higher speed than a 24.6 inch tire.
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173566
02/07/12 01:26 AM
02/07/12 01:26 AM
Manitoba, Canada
Manitoba, Canada
[sigh] I wasn't disagreeing with you on what you think I am but it's not worth the effort to articulate my point.
Re: How do I calculate final gear ratio? [Re: DaytonaTurbo] #1173567
02/07/12 01:29 AM
02/07/12 01:29 AM
Orleans, Ontario
Orleans, Ontario
Sorry you feel that way. It's a simple discussion.
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173568
02/07/12 01:52 AM
02/07/12 01:52 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It's still 3.23:1. The only thing you have calculated is what gear ratio would give you that speed with a 26.whatever tire.
Kevin
Re: How do I calculate final gear ratio? [Re: Twostick] #1173569
02/07/12 01:58 AM
02/07/12 01:58 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I like this calculator. Plug in numbers and have fun. Idk what you are trying to do. I think you are reverse thinking this just for curiosities sake. Instead of finding the change in rpm with the new tires you are looking for the change in gear ratio, if I understand you correctly.
Well, here it is:
http://www.csgnetwork.com/rpmcalc.html
Re: How do I calculate final gear ratio? [Re: MuuMuu101] #1173570
02/07/12 02:10 AM
02/07/12 02:10 AM
Orleans, Ontario
Orleans, Ontario
I have to agree with Daytonaturbo.
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173571
02/07/12 02:30 AM
02/07/12 02:30 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
This thread is an utter FAIL on so many levels.
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173572
02/07/12 06:11 PM
02/07/12 06:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well if it took 2650 rpm to go 60 with 24.6 tires it will now take 2277
if you were going 60 with the 24.6 tires you will now be going 68 ??
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173573
02/07/12 06:34 PM
02/07/12 06:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
and that is what i have read that every 1" tire change will change the gear .10 like you did.dont let them get in your head and mess thing up.
Re: How do I calculate final gear ratio? [Re: Dodgem] #1173574
02/08/12 02:35 AM
02/08/12 02:35 AM
Orleans, Ontario
Orleans, Ontario
if you were going 60 with the 28 tires you will now be going 68 ??
At 2650 rpm with 28" tires - Yes!
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173575
02/08/12 03:10 AM
02/08/12 03:10 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
The rpm with your 28" tire is the same as it would be with your stock tires and a 2.84 gear. A 28" tire doesn't magically make your 3.23s into 2.84s, it just makes your 3.23s feel like you kept your old tires and swapped to 2.84s. All you are doing is calculating the effective gear ratio difference due to your change in tire diameter.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173576
02/08/12 08:05 AM
02/08/12 08:05 AM
arkansas
mikemyke71 Offline
mikemyke71  Offline
arkansas
Put the Car in Gear, push peddle on right down to the floor, if front tires come off the ground,, you did a good job...
Re: How do I calculate final gear ratio? [Re: phantomx] #1173577
02/08/12 10:02 AM
02/08/12 10:02 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Travis..
Guys, I am pretty sure the original poster is well aware of this fact, and he simply wanted to know what his new tires would FEEL like in terms of rear gear ratio.
we all talk about "going from 3.55s to 3.91s really wakes up your car and gives it a stronger off the line punch" well...what DOES that mean, really? how do you put a number on a feeling? all the OP is trying to do, is put a number on a feeling.
Most car guys will talk about what their rear gear ratio is when in casual conversation. For example, I say my Dakota has 3.92 gears in the rear axle. I don't bore the person to death in a casual conversation by saying "my dakota has a 3.92 gear ratio in the axle, I'm running a 28.3" tall tire, and my first gear ratio in my transmission is a 3.48, my second gear ratio is a...."
because what use is the rear gear ratio, when you can have a 3.55 gear set in the axle that drives like a 3.92 simply by having a transmission with lower gear ratios.
by trying to put everything in terms of "effective rear gear ratio" it's just a way to standardize what everyone is talking about.
**Photobucket sucks**
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173578
02/08/12 07:35 PM
02/08/12 07:35 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Yes, but this statement right here leads me/us to believe that the OP feels that his car has 2.84s due to the tire change. It does not, it is only equal to how the car would feel with 2.84s and the original size tire. If his car originally had shorter tires the 28"ers would make it feel more like 2.60 or 2.70, or if he had say 27" tires originally the 28s would feel more like a 3.0 gear. It's a simple comparison derived from his original tire diameter.
Travis..
Re: How do I calculate final gear ratio? [Re: phantomx] #1173579
02/08/12 10:22 PM
02/08/12 10:22 PM
Orleans, Ontario
Orleans, Ontario
D'uuuuuuuuuuuuuuhhhhhhhhhhhhhhhhhhhhhhhh. I'm not so stupid to think that my gear 3.23 gear would magically turn into a 2.84. C'mon guys, a little thought before posting.
Travis..
That was my question in my first post!!!!!
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173580
02/08/12 11:00 PM
02/08/12 11:00 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
You're overkilling the double facepalm picture.
Re: How do I calculate final gear ratio? [Re: MuuMuu101] #1173581
02/09/12 12:16 AM
02/09/12 12:16 AM
Orleans, Ontario
Orleans, Ontario
Can you blame me??????
Re: How do I calculate final gear ratio? [Re: moparcanuk] #1173582
02/09/12 10:09 AM
02/09/12 10:09 AM
the house on the left.
cogen80 Offline
cogen80  Offline
http://www.bigblockdart.com/forum/speedtire.php
