Re: by-passing ballast resistor
[Re: Danny]
#1173530
02/07/12 12:19 AM
02/07/12 12:19 AM
Posts: 15,487 Florida
scratchnfotraction
i solderd in a #10 wire in the BR shell to hide the fact it is by-passed. i run a full 12 volts to my pertronix points conversion and the 40,000 flamethrower coil. not what your asking though I have 12 yrs of MM,I have not read the last few,i best go catch up on the reading and check out the story
[Re: John_Kunkel]
#1173535
02/07/12 08:10 PM
02/07/12 08:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The factory bypasses the ballast when starting, for a hotter spark and a quicker start. You can also bypass the ballast in an WOT situation if you want. But it can burn out the coil or ignition box if done permanently. I'll admit I bypassed my ballast and had a coil take a dump, but it took a couple of years to happen, so YMMV.
[Re: Supercuda]
#1173538
02/07/12 11:52 PM
02/07/12 11:52 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Connect a voltmeter to a battery and crank the engine. You will notice that the voltage drops at least a volt or two. So, IMHO it should read "The factory bypasses the ballast when starting, to allow the full (reduced) voltage to reach the coil."
[Re: RodStRace]
#1173539
02/08/12 10:47 PM
02/08/12 10:47 PM
Posts: 273 WV
Danny
WV
