T&D saga #1173317
02/06/12 02:57 PM
02/06/12 02:57 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
so...after all the rocker posts, my heads are off for fresh/up. stage VI max/wedge, comp .663lift/312dur. cam, springs 220@1.90 580@1.25 640@1.20, valve clearance .137, 1.5 ratio. shift 6800/7000 rpm, never backed off for winter.
what do i look for other then coil bind,pushrod lenght etc, would like rockers to last more then 75/100 runs
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: T&D saga [Re: 440lebaron] #1173318
02/06/12 03:17 PM
02/06/12 03:17 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I'm a little confused about your post but let me begin by saying a set of T&D rockers will defiantly last more than 100 runs. The paired shaft (5/8”) are by far the best and cost a couple hundred more but you can take them off one cylinder at a time instead of the whole set of rockers. I say it all the time on here, once you buy a set of T&D’s you will never look back.
Re: T&D saga [Re: Biginchmopar] #1173319
02/06/12 03:24 PM
02/06/12 03:24 PM
westerly, ri. usa
westerly, ri. usa
single shaft system, i'ved had to "look back" six or seven times in the last five years
Re: T&D saga [Re: 440lebaron] #1173320
02/06/12 03:44 PM
02/06/12 03:44 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
if you're tearing up rockers with that cam and amount of runs something is flat out wrong.
Re: T&D saga [Re: jamesc] #1173321
02/06/12 04:10 PM
02/06/12 04:10 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Respectfully X2!!!
IMO, among other problems, your seat loads are low. Where are the rockers breaking? Any pics? Are ALL your numbers theoretical from the manufacturer or actual measurements? 3/8" .080" moly pushrods?
Measure EVERYTHING...
Test your spring compressors accuracy. (height and load)
Map your valve lift at the retainer as assembled.
What is the entire cam profile? .05"/.200"/ lobe lift
What is your retainer to seal clearence?
What is your scrub pattern?
Pushrod length correct?
I have seen adjusters oiling gummed-up with locktite.
There is a start. One more thing...
Re: T&D saga [Re: HardcoreB] #1173322
02/06/12 04:44 PM
02/06/12 04:44 PM
westerly, ri. usa
westerly, ri. usa
3/8 .120 pushrod, real spring pressure, comp springs #943 per cam list at 240@1.90 598@1.25 "new"
rocker breaks horozontal bottom side facing spring, spring dia. 1.55 plenty of clearance. plenty of oil. adjusters are out 1 turn per T&D.
scrub pattern?
Re: T&D saga [Re: HardcoreB] #1173323
02/06/12 05:37 PM
02/06/12 05:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Any pictures of the broken parts? I agree that something has to be seriously wrong with that set up. I have run a ton more spring pressure than that on the common shafts with no issues many times in the past. I have never broken one of thier rockers. I bought a set of heads from someone(whole other story)that had T&D common shaft rockers that obviouosly were never cared for and chucked some pushrods and they still were not broken. A number of them had bad bearings afterward and were very beat up but they were still in one piece.
Re: T&D saga [Re: Al_Alguire] #1173324
02/06/12 05:53 PM
02/06/12 05:53 PM
westerly, ri. usa
westerly, ri. usa
photos tonight
Re: T&D saga [Re: 440lebaron] #1173325
02/06/12 06:05 PM
02/06/12 06:05 PM
jamesc Offline
jamesc  Offline
i've never been a big fan of high spring pressures but one things for sure you run too little with a roller and yes you will break parts
Re: T&D saga [Re: jamesc] #1173326
02/06/12 06:18 PM
02/06/12 06:18 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i think something is of aswell,you shouldnt kill rockers especialy not good rockers like T&D i would look first at retainer to guide/seal clearance,valve/guide clearance and valve to piston clearance, are the valves perfectly straight?
im not an expert or profesional enginebuilder its just the first things i would have a look at
Re: T&D saga [Re: jamesc] #1173327
02/06/12 06:34 PM
02/06/12 06:34 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
he has a ? mark about scrub pattern. maybe roller is catching edge of valve. seeya.
Re: T&D saga [Re: rickraw] #1173328
02/06/12 06:49 PM
02/06/12 06:49 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
What rickraw said I had that problem with the Crane Gold rockers on stock heads,put a set of lash caps on and solved the problem. I just hope your problem is as simple as that.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: T&D saga [Re: MRMOPAR622] #1173329
02/06/12 08:49 PM
02/06/12 08:49 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
A friend of mine had a lot of problems with that set up on stage 6 heads. I had the same problems on a set of B1's with the single shaft system. The problem was really spring size. The T&D with the common shaft deal, needs to have perfect geometry, perfect pushrod length, and can only be adjusted down 1-1 3/4 turns, with adjuster backed all the way to the top of the rocker. Also, the rockers are only suited to use a 1.55 valve spring. They relieve the rocker at the fulcrum to fit a 1.60, but it can weaken the rocker. That's why those of us with the bigger springs, with higher pressres buy the paired rockers. Call T&D and they'll tell you all about it.
Re: T&D saga [Re: camastomcat] #1173330
02/06/12 10:08 PM
02/06/12 10:08 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I run the T&D single shaft with 1.640 dia springs no problem with them hitting my springs but they are 2 years old maybe they changed there specs It's a B1 head
Re: T&D saga [Re: JD Dart] #1173331
02/07/12 03:27 AM
02/07/12 03:27 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The newer T&D rockers do not have any clearance issues. The older(blue)ones did. They have solved that issue. Just FYI..
Re: T&D saga [Re: jamesc] #1173332
02/07/12 04:33 AM
02/07/12 04:33 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
spring pressures when using a roller and given a choice I would rather too much than too little.
rollers will be bouncing like rubber balls
home of the
Sox and Martin Hemi Duster
Re: T&D saga [Re: 440lebaron] #1173333
02/07/12 10:37 PM
02/07/12 10:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
how many runs on the springs to get them to lose 20lbs seat pressure?
new, those springs are closer to 250-260lbs @ 1.900.
for now i'll only add that sometimes certain spring and cam profiles just arent happy with each other. my guess is, your valvetrain is going into spring surge and thats whats causing the breakage.
i would up the pressures, and switch to a different spring.....maybe something with a damper.
do you have the cam lobe numbers??
Re: T&D saga [Re: fast68plymouth] #1173334
02/07/12 10:58 PM
02/07/12 10:58 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
he was suppose to post pics of his broken rockers. guess that isn't going to happen. i bet the retainer is hitting the rocker. when i rebuilt my engine 2yrs ago, previous builder didn't have the stand shimmed properly & the retainer was just scrape the blue off the rocker. these are the blue t&d's, 1.65- 1.60, sb, w9's. i have a perfect scrub pattern, no problems. seeya.
Re: T&D saga [Re: rickraw] #1173335
02/07/12 11:55 PM
02/07/12 11:55 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I was beaking 1.5 INDY rockers on my 440-1 heads on a 446 and i built a 572 with same heads but got a set of T&D 1.6 and i had to put lash caps on and i have a bigger cam and i run it all last season and had ( NO TROUBLE )
Re: T&D saga [Re: steeldust] #1173336
02/16/12 02:28 PM
02/16/12 02:28 PM
westerly, ri. usa
westerly, ri. usa
ahha, some installed hights are off. some as high as 1.977. that puts springs at 180lbs closed. way to low seat pressure. now i feel better somewhat.
2.037 without spring locator. 2" spring with .030 shim should be just right
gary
seeya
