Winter or extended storage of vehicle #1173273
02/06/12 12:28 PM
02/06/12 12:28 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
My car sits there for a while the the garage...sometimes up to 3 months at a time. The suspension is under load. Could I buy four bottle jacks and place them under the subframe and lift the tires 1/2" off the ground just to reduce the tension in the suspension? Would four 2-ton bottle jacks be able to stay under a hydraulic load for three months or will a seal burst and lower one corner of the car? They advertise them locally for $15 each...probably the same quality as a Harbor Freight product. The other brand is $60 per jack.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Winter or extended storage of vehicle [Re: Pyper70] #1173274
02/06/12 12:45 PM
02/06/12 12:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Thousands of cars and trucks sit for extended periods. I wouldn't loose any sleep over it.
Re: Winter or extended storage of vehicle [Re: Pyper70] #1173275
02/06/12 09:47 PM
02/06/12 09:47 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
My car sits all winter and most of the summer, shhhh in the garage covered up. Lifting it and an un sprung suspension does more harm then good. Back in the day cars were lifted so bias ply tires weren't flat spotted, not a real problem with modern radials. Cars are parked on the street all the time and no problems. Be more concerned with rodents and covering the car and gas contamination.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Winter or extended storage of vehicle [Re: 340wedge] #1173276
02/07/12 12:01 PM
02/07/12 12:01 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Always indoors, always under a cover. Bought some tire covers and put them on recently. I have moth balls hanging around the suspension because mice apparently hate the smell along with some rodent killer yummies underneath the car
