will it be absolutely necessary to mill the heads?
#1173157
02/06/12 09:01 AM
02/06/12 09:01 AM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Hello everybody,
I have a set of new MP 452 heads in the box(84cc chamber)for my 440 engine. Using a comp calculator i would get a comp ratio of 9.30 with a .039" gasket.
Well, i sent a mail to Hughes for ordering one of their whisplash cams,and they said to me that 9.30 is too low for aluminium heads and i will need to mill the heads 0.50 or 0.60.. Also said that a .020 gasket is not an option for alu heads.
I,m not very happy about that idea...troubles with the intake fitment,valve clearances etc... What is your opinion?
Thanks a lot in advance for any input.
Re: will it be be absolutely necessary to mill the heads?
[Re: Coke]
#1173160
02/06/12 11:35 AM
02/06/12 11:35 AM
RapidRobert
I'd have the heads' deck milled then set the heads on head gaskets on the block then mockup/set the intake and its' gasket on there & see how far the port/bolt hole alignment is off then another trip to the machine shop to have the heads' intake faces' milled. It's not easy but later on when done & frying the tires cause you got every sub system dead on or near dead on (depending on the system) you'll have forgotten about the time/effort/occaisional aggravation that it took to get you there
[Re: dogdays]
#1173162
02/06/12 01:49 PM
02/06/12 01:49 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
What planet are we on?
Someone help me out here...the only Mopar 452 heads with which I am familiar are cast iron stockers from the late '70s, usually 90 - 92 cc chambers.
I've never associated that number with aluminum heads.
If the refrigerator magnet sticks to them they are cast iron. In that case 9.30:1 is a very usable compression ratio for pump gas.
R.
EARTH ...
MP sells an NHRA stock legal head called the 452 , it's an Ebrock head with straight plugs and a freeze plug in the slab ended head. Since NHRA was allowing outer makes to use it in stock they finally allowed Mopar one also.
[Re: JohnRR]
#1173163
02/06/12 03:31 PM
02/06/12 03:31 PM
dogdays
[Re: dogdays]
#1173164
02/06/12 03:53 PM
02/06/12 03:53 PM
JohnRR
U.S.S.A.
Well, I'll be dogged! R.
They have been out for a couple years now , but you have been away from the site ...
[Re: JohnRR]
#1173168
02/06/12 09:58 PM
02/06/12 09:58 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Actually, over five years.
[Re: BSB67]
#1173169
02/07/12 02:12 AM
02/07/12 02:12 AM
JohnRR
U.S.S.A.
I'm screwed either way , I was going to say they have been out for a number or years and then second guessed my self expecting a ... actually they came out last year ...
[Re: JohnRR]
#1173170
02/07/12 08:33 AM
02/07/12 08:33 AM
BSB67
Prospect, PA
Yeah, I did not mean it as nit-picking. When I read yours, I said to myself, "I think its three years", then walked over to my files. Man, the time sure goes, but I belive your point was simply ,...they've been around for a while...., and they certainly have.
[Re: dogdays]
#1173171
02/07/12 08:52 AM
02/07/12 08:52 AM
Coke
Vitoria, Spain
Thanks a lot for all the replies Dogdays, The pistons are flat ,stock style,TRW L2388,1.926" comp distance . The deck is not exactly the same in all the cyls,but they are between .068" wich is the one most closer to the surface and .074" that would be the most deeper in the hole. The Whiplash cam lift is .518". What i thought,or at least what i have read in some web page, is that the Alu heads subtract one pound from the compresion,but they compensate that loss of power in other ways. So if it is 9.30:1 would it go to 8.30:1? Here is a link to Youtube about a 66 Coronet wich is running a very similar set up,440 engine ,Whiplash cam and 452 heads.(The cast iron ones ?)The engine is from a motor-home,8.5 comp ratio and the owner seems to be very happy with it... http://www.youtube.com/watch?v=MjeCyVvg4Ss
[Re: Coke]
#1173172
02/07/12 10:49 AM
02/07/12 10:49 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
Dogdays,
The pistons are flat ,stock style,TRW L2388,0.75" comp distance . The deck is not exactly the same in all the cyls,but they are between .068" wich is the one most closer to the surface and .074" that would be the most deeper in the hole. The Whiplash cam lift is .518".
What i thought,or at least what i have read in some web page, is that the Alu heads subtract one pound from the compresion,but they compensate that loss of power in other ways. So if it is 9.30:1 would it go to 8.30:1? ]
The guys here will correct me if I'm wrong, but I think it's not that aluminum lowers compression, but more like you can run more compression with aluminum than an iron head without detonation, all things being equal.
[Re: bobs66440]
#1173173
02/07/12 11:29 AM
02/07/12 11:29 AM
JohnRR
U.S.S.A.
This is what everything points to .
Coke , with pistons that deep in the hole you'll have no issues with piston to valve interference. but you'll want to be careful with compression being too high without the benefit of quench because of how deep they are in the hole.
[Re: JohnRR]
#1173174
02/09/12 08:28 AM
02/09/12 08:28 AM
Coke
Vitoria, Spain
It seems that they dissperse the heat a lot faster than the iron,wich means that they would evite detonation on a 10:1 and upper CR,but i don,t know what would happen with the power on an engine with less than 10:1.
John, Do you mean that the compression could damage the gasket triying to scape ?That is the explanation that i find,cause the quench is the flat part of the piston wich leves with the block surface,but this would be on a dish piston,six pack style for example.
However 9.3 or 9.5:1 CR wouldn,t be a trouble,would it?
Thanks both of you
[Re: Coke]
#1173175
02/09/12 10:48 AM
02/09/12 10:48 AM
JohnRR
U.S.S.A.
Thanks both of you
No the compression won't damage the gasket . Your compression ratio under 10 is fine as long as you don't run the lowest octane fuel available .
I'm not getting your question , your english is generally good but I'm a little confused by
is that supposed to read
the flat part of the piston which levels with the block surface ... meaning zero deck ?
[Re: JohnRR]
#1173176
02/09/12 03:01 PM
02/09/12 03:01 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I believe Hughes told you that because the aluminum head can run about 1 point higher in comp to be equal with and iron head. So if you run 10.5 with the 452 aluminum head its like 9.5 with the cast iron head. I can tell you we milled the Eddy heads on my sons 400 .040 to get 10.8 comp. It does not have good quench but runs fine on 92 or 92 pump and it has no fitting problems as we milled the intake side .040 also.
Sure you can run the comp at 9.5 but you will have a little better performance if you up the aluminum headed eng to 10.5. You will just loose a tad of power at 9.5. That said I run 10.6 in my aluminum headed 493 and it does have quench and runs great on 92 pump. Ron
