Re: aluminum ring on dist. shaft
[Re: Bigcube]
#1172726
02/07/12 05:29 PM
02/07/12 05:29 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I still use the rubber pipe, just change it once every 6 mths. I'm a bit twitchy about the screw coming loose and falling out. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: WHITEDART]
#1172727
02/07/12 07:43 PM
02/07/12 07:43 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
hey don if you have a chain u will still have low speed bounce it should go away at about 3000 rpm. Have you seen the guy out at irwindale that lighted his 1969 dart buy using plastic bags. As a floor in the trunk no wonder that thing is so fast
dude, thats funny!!!!!!!! with a name like deepockets, you'd think he would open his wallet and cover it with aluminum
