Re: 74 and up steering box in a 65 coronet?
[Re: Andrewh]
#1172157
02/05/12 01:52 AM
02/05/12 01:52 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Is there a difference in length between the newer and older arms? If so you need to change the idler arm. That would require building a new mount on your K-frame.
[Re: feets]
#1172158
02/05/12 01:55 AM
02/05/12 01:55 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Pitman arm length & effective shape are the same, the pitman shaft is larger so the hole in the arm is larger to match.. The high pressure fitting that the hose attaches to needs to be kept off the old box...
