Re: how much hp can a 8.75 differential take?
[Re: JohnRR]
#1170496
02/02/12 01:30 PM
02/02/12 01:30 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
you can do all the mods you want to the 8.75 , billt caps , axles , back brace the rear , spool , in the end the weak link still exists ... the gears ...
John,everything is made to be broken,that's why there are replacements.
[Re: DGS]
#1170497
02/02/12 02:15 PM
02/02/12 02:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Do yourself a favor, put a DANA 60 under it, and have no worries.....I've toasted so many 8 3/4 axles/chucks, I won't put one under a decent small block, nevermind a bigblk unless the build requires it I've even wasted a DANA 60, they're not indestructable, but a he11 of a lot more than a 8 3/4 IMHO..... spend the once, rather than twice
[Re: DAYCLONA]
#1170498
02/02/12 02:32 PM
02/02/12 02:32 PM
Posts: 91 just south of Green Bay wiscon...
Rob74
i dont know i have a 8 3/4 with a back brace and a spool with 35 spline axles in my cuda with 31/18.50 hoosier qt pros with a trans brake pulling 1.50 60 footers and never had a problem.. Rob
down to just one toy still got my 74 pro street/drag cuda with a best of 10.89@125..i know weak huh?
[Re: Rob74]
#1170499
02/02/12 03:11 PM
02/02/12 03:11 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
There's always one in the crowd ..
I wasted an 8.75 behind a 340 with a 4speed and NO traction ...
[Re: JohnRR]
#1170501
02/02/12 03:45 PM
02/02/12 03:45 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
don't know how..340's can barley make enuff power to spin the tires. It must have been really old and worn out. That or you had a ton of wheel hop.
[Re: Mr.Yuck]
#1170502
02/02/12 04:04 PM
02/02/12 04:04 PM
Challenger 1
Cincinnati, Ohio
[Re: Challenger 1]
#1170504
02/02/12 06:29 PM
02/02/12 06:29 PM
JohnRR
It regularly got spanked by an 81 horizon running on 3 cylinders ...
[Re: 62maxwgn]
#1170505
02/02/12 07:11 PM
02/02/12 07:11 PM
Posts: 2,042 colorado
savoy64
colorado
Go get a Furd 9"...all the racers use them
to all the non readers out there SAE engineers put the 8.75 (741) vs 9 inch to the test years ago and found the 8.75 was good to 500 hp and the ford 9 to 450 hp---the 9,s weakness is the pinion sitting at the bottom of the ring gear-----yes the after market chased the 9 the way it chased the sbc so there is a ton of things that can be done to it to make it stronger---but after spending $1000+ you might as well build a dana 60----and if you think the aftermarket is really right maybe you 9 inch guys should belly up to a sbc and gm trans and laugh at us forlorn mopar guys and our backwards ways(and dont even get me started on the 8.8)bob---hahahah
[Re: RUNCHARGER]
#1170507
02/02/12 10:16 PM
02/02/12 10:16 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Early funny cars and dragsters ran Blown Hemi's with 8.75 rear ends. The drivers important parts sat straddling the pumpkin. Like everyone has said, with street tires you are not going to have trouble. If you had a stick and slicks dont use the 8.75.. I would recommend the POWER LOC differential unit.
[Re: JohnRR]
#1170509
02/03/12 01:27 AM
02/03/12 01:27 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Eh....he just put the "kabosh" on himself,....he'll grenade on the next launch
[Re: DAYCLONA]
#1170510
02/03/12 01:37 PM
02/03/12 01:37 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
And I'm not saying a word 'cause I don't want to put the "kabosh" on myself
1.389 60' @ 3,325#
[Re: 70 Roadrunner*]
#1170512
02/03/12 03:26 PM
02/03/12 03:26 PM
Mr.Yuck
Brookeville, Md
JohnRR...You said there's not much traction to BFG 295-50-15s? Damnnit I just spent a bunch of coin on a fresh set of rears!...and was hoping for traction ...this sucks
Radial tires (street tires) were not made for all of a suddent all out WOT. They were made for driving. If you want a tire for "sudden starts" you are going to need some sort of a slick. Even a well tuned 3182bl is going to smoke up a radial. I have a set of tires I use for driving and a set that goes on for the track.
