Re: how much hp can a 8.75 differential take?
[Re: DANA60]
#1170478
02/02/12 10:53 AM
02/02/12 10:53 AM
Posts: 640 Graz, Austria
DGS
Graz, Austria
Car is a 1970 Charger R/T 440 auto. weight is around 3800lbs, tires are BFG Radial T/A 295/50 R15 diff case is a 489 driving style? mostly regular street driving with an occasional stop light to stop light sprint
[Re: DGS]
#1170479
02/02/12 10:54 AM
02/02/12 10:54 AM
Posts: 2,177 ill
dennismopar73
ill
8 3/4 alot stronger than you think, and will hold up quit awhile. Age is a killer anything will break over time, always use new gears bearings, and a good yoke! set up will be the main deal ,if not right will cost you in the long run! try to find a good case 742 is one of the best cases to look for, 489 is most common, some will say the 741 is weaker, but , I have run it , raced it never issue , but as I said age and passes, yes, hp /tq /weight, also plays somewhat into the mix, good luck!
[Re: DGS]
#1170484
02/02/12 11:17 AM
02/02/12 11:17 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
8.75 will be fine , you'll have little traction with those tires , just don't buy a cone type suregrip of any make.
[Re: 70Cuda383]
#1170485
02/02/12 11:21 AM
02/02/12 11:21 AM
DGS
Graz, Austria
I know that the 8.75 is a reliable axle - I'm concerned about the sure grip differential. Especially the Detroit TrueTrac.
I don't know who told you the Detroit TrueTrac is only good for 350 ft lbs of torque. I seem to remember a story a few years ago in one of the mopar mags where Detroit said "you can't break this diff. you'll break other parts before you blow up this true-trac." and they tried to break it with slicks big block power and 11 second time slips (all from memory, it's been a few years since I saw that article)
I had a detroit true trac behind my 383 stroker making 535 ft lbs of torque, in a 4200 lb pick-up truck, with a manual transmission
it did just fine.
sounds good to me! I'll get a TrueTrac then and sell my cone style SG (looks almost new but is a Borg Warner type).
[Re: JohnRR]
#1170486
02/02/12 11:22 AM
02/02/12 11:22 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
no kidding I put the slicks on the shelf and put my 265/60/16 T/A's on the car and it's like I'm driving on ice. One small blip of the throttle and the tires start turning...doesn't matter if I'm in 1st 2nd or 3rd at almost any speed.
[Re: Mr.Yuck]
#1170487
02/02/12 11:44 AM
02/02/12 11:44 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Yep, 295 BFG's have very little traction and that's what it's all about: TRACTION, not HP, not torque....TRACTION is what can hurt diffs. There is no problem with an 8 3/4 being used for the OP's stated useage. Even occasional track use with slicks and it would be just fine. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: dustergirl340]
#1170489
02/02/12 12:30 PM
02/02/12 12:30 PM
Mr.Yuck
Brookeville, Md
Heavy weight + lots of torque + sticky tires = ouch
We will find out in the spring. I have a few upgrades and I'm going to run it 100% for the 1st time. Looking for about a 1.50 60 foot and 11.teens (or better)at 120+
[Re: JohnRR]
#1170493
02/02/12 01:16 PM
02/02/12 01:16 PM
DPelletier
Were the 8 3/4 not strong enough for the 62/65 Super Stock cars ?
Maybe they were for those ... ...
you can do all the mods you want to the 8.75 , billt caps , axles , back brace the rear , spool , in the end the weak link still exists ... the gears ...
Sure but if Mopar never chose to start using the Dana 60, all we'd hear is how much better the 8 3/4" is over a GM 12 Bolt!
Truth is the 8 3/4 is a relatively stout setup and was used behind many Hemi, Max Wedge and 440-6 cars with no huge issues.
If you are going to build a drag car then sure, use the Dana, but for most people and most applications the 8 3/4" works just fine.
1974 'Cuda
