""You do realize that your above statement is a bit contradictory right?
While most FAST racers do make a few modifications that detract from a 100% "OE" appearance, most are simply because it's needed in terms of safety & performance, all other details (to the smallest degree) can be addressed to make them as close as original. This is already being done by at least a couple racers including Dave Dudek.
*Starters were not engine color (black can, "as cast" body), niether were transmissions, (autos were bare cast aluminum, 4 speeds bare cast iron)""
Ok maybe a little contradictory ..
Ive been wrestling this dipstick for three hours ... I lost internet and power for two of them --
working off a generator for lights worked out well .. Powers back now ..
Ok I found throttle cable retainer Unpainted
Scotts picture looked like the starter intact ..
It is not .. cast color is correct ..
Its amazing after loking at A book I got for Xmas on HEMIS -- How many details are incorrect..
( based on what Ive learned with this project )
My car probably will never be as nice as Daves ..
I dont know how he does it ... His stuff is nice ..
If anyone has a detail of the drivers side of the engine .. Thatd be great ..
Every reference book I have is not clear enough ..
Thanks In advance ..
I am slowly getting convinced that my repop dipstick from Mancini may not be bent at the right angles OR I have motor mount conflicts ..
So much for beefy Poly mounts ..
Details , Details , Details ..
