did you check the pick up in the tank? they will rust and get holes and when the fuel level drops it will suck air.
look at how much fuel you have when it acts up.
sounds like a clogged fuel filter also.
could be the ecu going out or a weak coil getting hot(you changed that though?)
look the fusable link wires over for the ign power,have seen the almost burt and get hot and lose power cool off restarts.
dont know what elect ign it was changed to but 84 would have already been ecu/elect dist.
I always run a points dist with pertronix conversion,by-passing the BR for a full 12volts to the coil...never had to mess with it after that.
could very well be a fuel pump going out also,look at it and see if the weep hole is leaking gas,check the oil to see if it smells like gas.
what carb does it have? does it have a built in filter or stone?
what gas cap does it have ? should have a vented cap,a non vented cap would build vac and fuel pump cant suck fuel.
R&R the VR and ecu and clean the part that grounds them/firewall together.
do you have ground straps on the Batt/engine/core support/firewall ??
what I come up with thinking about the symptoms you desribe
