Winter upgrade, Roll cage and subframe connectors #1168168
01/29/12 11:45 PM
01/29/12 11:45 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
The goal was to add a full cage to the car, and this is the thread where I will be talking about it. The cage is being installed by MW Racecraft, out of Coon Rapids, MN. http://www.mwracecraft.com/ The cage is a 10 point if I don't end up installing the front bars, or a 12 if I do install the front bars. The goal here is to be able to use the entire interior. Rear seat, side panels, door panels, even the factory headliner AND dome light. Big order? I would say so. Granted the carpet will have to be custom, and I have to modify the dash some for the A pillar bars, being as I must be able to remove the dash once the cage is in place. Keep in tune for more pictures as the build progresses. Here are some pics.
the subframe connectors
so far the back of the cage has been mocked up and tack welded in place.
Re: Winter upgrade, Roll cage and subframe connectors [Re: moparguy] #1168169
01/30/12 12:36 AM
01/30/12 12:36 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
looking good whats the plan for the car..set up
Re: Winter upgrade, Roll cage and subframe connectors [Re: earthmover] #1168170
01/30/12 01:49 AM
01/30/12 01:49 AM
Do the base plates not need to be at least 6"x6"?
Yes it does look good.
Re: Winter upgrade, Roll cage and subframe connectors [Re: ] #1168171
01/30/12 07:42 AM
01/30/12 07:42 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Yes they need to be 6x6, and 1/4" thick, unless they are welded to the frame on a full frame car.
Jeff
69 GTX 68 Road Runner
Re: Winter upgrade, Roll cage and subframe connectors [Re: ] #1168172
01/30/12 09:43 AM
01/30/12 09:43 AM
Coon Rapids, Minn.
MW Racecraft Offline
Coon Rapids, Minn.
The rear bars actually go thru the
frame. They are welded to the frame
in 2 places. The bar runs thru the
top plate also. The plate is 3x6.
On the bottom of the frame is the
design with at 2x6 plate. Contacted
NHRA Tech about is design, and they
responded ok.
Re: Winter upgrade, Roll cage and subframe connectors [Re: JERICOGTX] #1168173
01/30/12 10:06 AM
01/30/12 10:06 AM
Coon Rapids, Minn.
Coon Rapids, Minn.
As per the rule book, the plates are
required to 1/8 thick.
Re: Winter upgrade, Roll cage and subframe connectors [Re: MW Racecraft] #1168174
01/30/12 11:51 AM
01/30/12 11:51 AM
Az
Crizila Offline
Crizila  Offline
Az
and6X6"
Fastest 300
Re: Winter upgrade, Roll cage and subframe connectors [Re: Crizila] #1168175
01/30/12 09:02 PM
01/30/12 09:02 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Good luck with it: i'll be watching this thread
Re: Winter upgrade, Roll cage and subframe connectors [Re: moparguy] #1168176
01/30/12 09:27 PM
01/30/12 09:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks for the pics. Always interesting to see how others do it. I just finished putting a 10 point cage in a late B body - which nobody makes a kit for. Ended up losing most my interior - and dash. No big deal as I was looking to lose as much weight as possible anyway. Bought an E body kit from Jegs which was relatively close ( main hoop anyway ) and built it as close to their drawings as possible. Front down bars sit on a 6X6 plate, but I had to build an inclosed box for the plate to sit on, as the floor was not flat in that area. This is a unibody car so no frame in this area. Didn't have a problem with NHRA tech as I raced this weekend. I'm sure there are a lot of variables that they see - and have to decide on.
Fastest 300
Re: Winter upgrade, Roll cage and subframe connectors [Re: Crizila] #1168177
01/30/12 11:34 PM
01/30/12 11:34 PM
Coon Rapids, Minn.
Coon Rapids, Minn.
We are going to use 2x3 tubing up front.
Going to connect front subframe to sill
plate with 2x3 tubing and gussets. Drop A pillar bar down on the tubing.
Will post pictures when we get up front. Finishing back now.
Re: Winter upgrade, Roll cage and subframe connectors [Re: MW Racecraft] #1168178
01/30/12 11:40 PM
01/30/12 11:40 PM
Az
Crizila Offline
Crizila  Offline
Az
Should be bullet proof!
Fastest 300
Re: Winter upgrade, Roll cage and subframe connectors [Re: Crizila] #1168179
01/31/12 02:21 PM
01/31/12 02:21 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looking sweet. The rear portion is similar to how we are doing my Challenger right now.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Winter upgrade, Roll cage and subframe connectors [Re: 6PKRTSE] #1168180
02/08/12 01:08 AM
02/08/12 01:08 AM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
Some update pics!
He has the rear all set up and welded in place. Mike also welded a few nuts into the rear bars for a good ground, and has setup the battery disconnect since the battery is going out back. the rear is also setup for a fuel cell that I'll be putting in sometime in the relatively near future. I'm incredibly pleased with how this has turned out so far. Now onto the front of the cage! :2thumbs:
apparently I am still technologically retarded.
lets try this again.
[image] http://imageshack.us/photo/my-images/403/trunkarea.jpg/[/image]
[image]http://imageshack.us/photo/my-images/600/trunkarea3.jpg/[/image]
[image]http://imageshack.us/photo/my-images/708/trunkarea2.jpg/[/image]
[image]http://imageshack.us/photo/my-images/809/trunkarea1.jpg/[/image]
[image]http://imageshack.us/photo/my-images/267/dbar1.jpg/[/image]
[image]http://imageshack.us/photo/my-images/696/dbars.jpg/[/image]
[image]http://imageshack.us/photo/my-images/812/interiorupfront.jpg/[/image]
[image]http://imageshack.us/photo/my-images/841/interiorseatbar.jpg/[/image]
Re: Winter upgrade, Roll cage and subframe connectors [Re: moparguy] #1168181
02/08/12 10:12 AM
02/08/12 10:12 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
none of those chicken scratches work...
Re: Winter upgrade, Roll cage and subframe connectors [Re: smokinwoody] #1168182
02/08/12 04:34 PM
02/08/12 04:34 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
Re: Winter upgrade, Roll cage and subframe connectors [Re: moparguy] #1168183
02/08/12 06:12 PM
02/08/12 06:12 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
looks real stealth...
Re: Winter upgrade, Roll cage and subframe connectors [Re: W9 Dart] #1168184
02/08/12 07:00 PM
02/08/12 07:00 PM
Indiana
SB Dakota Offline
SB Dakota  Offline
Indiana
now thatis real sweet looking. i like that alot
Larry Anderson 87 Dodge Dakota 416 Stroker 71 Dodge Dart http://i58.photobucket.com/albums/g254/rules371/88888888888-1.jpg
Re: Winter upgrade, Roll cage and subframe connectors [Re: SB Dakota] #1168185
02/09/12 02:20 AM
02/09/12 02:20 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Nice craftsmanship is that cm/ms?
Re: Winter upgrade, Roll cage and subframe connectors [Re: racerx] #1168186
02/09/12 10:16 AM
02/09/12 10:16 AM
Coon Rapids, Minn.
Coon Rapids, Minn.
Cage is mild steel.
Re: Winter upgrade, Roll cage and subframe connectors [Re: racerx] #1168187
02/09/12 07:36 PM
02/09/12 07:36 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
ya, its mild steel. The goal is to make it minimally visible from outside the car as well. so far Mike has done an awesome job with that. Thanks for the kind words fellas.
