Re: 1966 charger brakes
[Re: yakpenoose]
#1168051
01/29/12 10:56 PM
01/29/12 10:56 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Scarebird is the cheapest way to do it without having to scrounge up junkyard spindles. You can buy everything new this way if that's your preference. http://www.scarebird.com/
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: yakpenoose]
#1168052
01/29/12 11:01 PM
01/29/12 11:01 PM
Posts: 31,050 Oregon
AndyF
i was hoping there was someplace that has a complete kit for this swap.....
There are lots of kits available. The problem is that many of the kits use junk parts.
Best deal is to swap on the late model A body disc brakes. Then you have OEM quality parts and repairs are easy down the road. You can buy the A body brakes in kit form if you want, but sometimes the quality of those kits is suspect too.
[Re: AndyF]
#1168053
01/29/12 11:03 PM
01/29/12 11:03 PM
Secret Chimp
Eugene, Oregon
I forget where, but somebody tested out other spindles (Cordoba, Diplomat, etc) and found that while they did have a less desirable toe curve or something, only the hardest driving would reveal it. A-body disc spindles are really hard to find in some parts.
