470 Low Deck for the Ugly Aries! #1167982
01/29/12 08:46 PM
01/29/12 08:46 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Here are the secret spy photos of the shop of the Ugly Aries. After 1000's of passes, the mule motor is out and the new 470 is ready.
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167983
01/29/12 08:48 PM
01/29/12 08:48 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
The mule motor is being torn down...
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167984
01/29/12 08:51 PM
01/29/12 08:51 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
A generic 440/Eddy head/.590 cam motor is also ready for another car...
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167985
01/29/12 08:53 PM
01/29/12 08:53 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Always ready to lend a (left) hand...
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167986
01/29/12 11:38 PM
01/29/12 11:38 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Should run well in this lightweight!
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167987
01/30/12 12:33 AM
01/30/12 12:33 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
of topic but how does this car handle on top being short wheel base??????could you give me a run down on the rear set up...looking at a short wheel base car and top end is what has been in the back of my head..thanks and nice set up you have there mike
Re: 470 Low Deck for the Ugly Aries! [Re: earthmover] #1167988
01/30/12 09:20 AM
01/30/12 09:20 AM
tboomer Online work
tboomer  Online Work
Looks good,Charley! Give us a rundown of the 470...
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167989
01/30/12 09:38 AM
01/30/12 09:38 AM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
As you can see Charlie needed to get out of the house. Knowing what I know now the mule motor would have been gone through and put back in the car as that combo in the car worked well. Still may happen , will just have to see how the new combo does.
Re: 470 Low Deck for the Ugly Aries! [Re: earthmover] #1167990
01/30/12 09:41 AM
01/30/12 09:41 AM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
Wheelbase on the car is 100". Previous owner went a best of 8.60's with the car at over 152. My slow setup went a best of 9.65 at over 137 with no issues.
Vernmotor does know the previous owner and I'm sure he can tell you how the car handles.
Re: 470 Low Deck for the Ugly Aries! [Re: tboomer] #1167991
01/30/12 09:47 AM
01/30/12 09:47 AM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
Eagle crank, rods with SRP flat top pistons (CR 11.4 to 1) Comp cams roller 661 lift with 270 duration @ .50. SR MW heads with a mild port and bowl blend with a 850dp on E-85. Should run 9.20's - 9.30's. Hope the car is as consistent as the old 590 combo was.
Re: 470 Low Deck for the Ugly Aries! [Re: RBDuster] #1167992
01/30/12 11:37 PM
01/30/12 11:37 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
I always have a nice time when I go to "visit my shut-in friend!"
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167993
01/30/12 11:40 PM
01/30/12 11:40 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167994
01/31/12 09:05 AM
01/31/12 09:05 AM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
It's easy being a shut-in in the winter when it's in a heated garage playing with man toys.
Re: 470 Low Deck for the Ugly Aries! [Re: cgall] #1167995
01/31/12 03:17 PM
01/31/12 03:17 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
What's so ugly?
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: 470 Low Deck for the Ugly Aries! [Re: BBLM23] #1167996
01/31/12 03:35 PM
01/31/12 03:35 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
how does the aries handle on top ???? rear set up if you dont mind thanks mike
Re: 470 Low Deck for the Ugly Aries! [Re: earthmover] #1167997
01/31/12 07:09 PM
01/31/12 07:09 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
No handling issues on top. Rear end is a 9" Ford with 4.56 gears. Ladder bars with strange double adjustable shocks. Tires are Goodyear 14x32.
