Re: Flow bench calibration question
[Re: Cab_Burge]
#1167539
01/29/12 12:53 AM
01/29/12 12:53 AM
Posts: 20,193 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The 110 is calibrated at 10 inches but check out the specs on the 600 and the 1020. When the industry standard is 28 why calibrate your bench at 25?
[Re: Cab_Burge]
#1167541
01/29/12 04:35 AM
01/29/12 04:35 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Flow benches are like dynos,flow bench operators and dyno operators are like the the equipment they operate,some happy,some sad.You can take the same set of heads 3 different benches and get 3 different results.Depending on the equipment,conditions,setup and the operator the results may vary.How many times are the conditions in a controlled enviroment(dyno room or flow bench)duplicated in the real enviroment that the parts are used in. Another consideration is imput information.Sometimes the results can be manuplated.Don't get me wrong here,flow benchs as dynos are great tools for engine building.A flow bench can help get you to the desired maximum flows and help balance all cylinder volumes equally for your build and tell you if you have any issues.But seriously if your buying a set of heads that have been CNCed by someone who has disected the design and mastered a program what more can you do other than little touch up here and there.
[Re: pittsburghracer]
#1167543
01/29/12 08:11 PM
01/29/12 08:11 PM
Posts: 2,091 Delray beach, Florida
Performance Only
I understand what you are saying Bob but there are a lot of inflated numbers floating around out there and a CNC program does not fix the problem. A CNC port is only as good as the hand ported head it was copied from. Indy is a perfect example as their flow numbers are always on the high side. Getting back to the question why would a major flow bench manufacture calibrate their bench at 25 inch instead of the industry standard 28?
pretty simple really, in the case of Superflow, that's how their benches are rated. the SF600 moves 600 CFM @ 25" and the SF1020 moves 1000CFM @ 25". the benches are calibrated at 25" to be sure they're working properly. if the bench won't pull 600 or 1000 cfm respectively it should serve as an alert to the operator of a problem that needs to be corrected. after the bench is calibrated you are ready to test at any setting you want. any of the SF benches i've been around that use the flow-com and motor controller have been extremely consistent from bench to bench. don't confuse calibration test pressure with actual testing test pressure.
machine shop owner and engine builder
