Anybody know why TB's are so lightly secured?
#1167425
01/28/12 09:03 PM
01/28/12 09:03 PM
Posts: 22,697 Bitopia
jcc
Bitopia
First, I am talking about the lightweight internal spring clip at the rear of the TM mount. Doesn't seem very robust. And doesn't it supply additionally a small amount of retention front to rear of the LCA? My guess was it's for safety, in a hard front end crash, TB just push rearward instead absorbing and releasing a lot of stored energy and entering interior of car? Well?
Re: Anybody know why TB's are so lightly secured?
[Re: jcc]
#1167426
01/28/12 09:16 PM
01/28/12 09:16 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
It would take a heck of a lot of energy to push a torsion bar through there with a clip still in it. Any way, most of the force in normal operation is torsional and pretty much none front to back. I have seen a couple cars riding around with the clips missing for who knows how many years and the bar does not try to move out.
[Re: HotRodDave]
#1167427
01/29/12 01:20 AM
01/29/12 01:20 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I agree here. It defies logic, but the T bars seem to stay put.
[Re: Kern Dog]
#1167428
01/29/12 01:23 AM
01/29/12 01:23 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Doesn't defy logic at all... There is so much torsional load locking the bar in position & absolutely nothing trying to force it to move in a linear fashion.. Why would you expect it to move?
[Re: 1_WILD_RT]
#1167429
01/29/12 06:13 AM
01/29/12 06:13 AM
jcc
Bitopia
Under heavy braking when traveling in reverse, the brake strut attaches to lca at what is basically a fulcrum, and the spindle pushes forward, and the lca tb mount point pushes rearward, against what, just a clip? A 180-360 spin at speed should be a decent amount of loading. Still leaning towards it is an accident breakaway solution.
[Re: jcc]
#1167430
01/29/12 11:06 AM
01/29/12 11:06 AM
Posts: 904 Berwyn, IL
Moparlar
Berwyn, IL
I think you might be over thinking this. I have taken out many torsion bars that were not even close to the clip. So they had not pushed back and if they had there is no way they could have moved back forward. I am sure the strut rod has something to do with that also.
Larry
[Re: jcc]
#1167433
01/30/12 03:47 PM
01/30/12 03:47 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Even with the front tires dangling in the air there is so much torsional load on the bars they will not come out. Think of the spring rate. Can you bench press the lower control arm while the t-bar is installed? All that pressure is mashing the hex ends into the sockets. You will not push them out. I've seen some cars that were in very serious collisions that didn't push the t-bars back.
It's simply a non-issue.
[Re: feets]
#1167434
01/30/12 06:46 PM
01/30/12 06:46 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
12 bolt clutch covers, 5/8 wheel studs, 8 bolt flex plates, billet rear end caps, 12 bolt ring gears, 1350 u-joints, grade 8 rim screws.......................... 4-1/4 fine thread bolts holding driveshaft to rear end!!
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Supercuda]
#1167436
01/30/12 11:10 PM
01/30/12 11:10 PM
jcc
Bitopia
Reg TB's being secured, I remember seeing here? years ago a pic of a nascar? early mopar TB secured by a bolted plate, for reasons unknown to me. And reg overthinking the question, I've heard that before
