Had the rear suspension on the 2002 stratus come apart on the way home thursday, but made it home. I took the two rear trailing arms apart over at my buddies shop summer and tried to give it a home brewed rear wheel alignment, and aparently didn't get the locknut tight enough. It's two spherical ends with a double ended threaded rod that allows it to be adjusted either direction. The outer arm actually dragged on the ground for the last mile coming up street,so it's abit messed up. I tried to look it up on the advance auto web site, but thier site sucks! Went and wasted 20 minutes at autozone by my work and they came out with the front tie rod end. (does the car have air conditioning? Duh!) Can anyone help figure out what the hell they call this freakin' part, and find it online. I tried calling it a rear tie rod end, and lower rear trailing arm with no results.
Mike
