HOW to test a HORN without damaging it???? #1165738
01/26/12 11:38 PM
01/26/12 11:38 PM
Fargo ND
moparphilll Offline OP
Fargo ND
Do u have to test a horn thru a horn relay or can u conect directly to 12 V battery without doing damage?
Re: HOW to test a HORN without damaging it???? [Re: moparphilll] #1165739
01/26/12 11:44 PM
01/26/12 11:44 PM
IMGTX Offline
IMGTX  Offline
You can hit it with 12V and it will be OK.
The relay only uses the Negative (Ground) signal created by pushing the horn button to create a positive voltage signal to the horn.
Re: HOW to test a HORN without damaging it???? [Re: moparphilll] #1165740
01/26/12 11:44 PM
01/26/12 11:44 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Yes you can test one on a battery without doing damage. The reason for the relay is not to protect the horn, it's to limit the current going through the horn contact in the steering wheel.
Re: HOW to test a HORN without damaging it???? [Re: 440newport] #1165741
01/26/12 11:53 PM
01/26/12 11:53 PM
Fargo ND
Fargo ND
Ok I have tested 3 and they sound once and then won't work so thought I was doing damage.
