What pullies do I need? #1165646
01/26/12 10:22 PM
01/26/12 10:22 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I am building a 400 that originally had AC on it. There will be no AC on the car it is going in after the build so I need to get a two groove crank pulley and a single groove water pump pulley for it. Can someone tell me what combination of diameter and depth of each pulley is that I need to get? Thanks in advance.
Re: What pullies do I need? [Re: 1970RT] #1165647
01/26/12 11:13 PM
01/26/12 11:13 PM
scratchnfotraction Offline
on my non a/c MH engine it has a # groove crank,2 groove wp,2 groove alt set up.
with PS it had one bet from crank,wp,alt
other belt was from crank,wp,ps pump
one crank groove not used.
when I droped the PS pump,i used 2 belts from crank,wp,alt
like this
Re: What pullies do I need? [Re: scratchnfotraction] #1165648
01/26/12 11:17 PM
01/26/12 11:17 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
adn not factory either
Re: What pullies do I need? [Re: scratchnfotraction] #1165649
01/26/12 11:20 PM
01/26/12 11:20 PM
like this
I like it
Re: What pullies do I need? [Re: RapidRobert] #1165650
01/27/12 12:42 AM
01/27/12 12:42 AM
IN
ahy Offline
ahy  Offline
IN
The pics on Bouchillon's site should help. If you need re-pop pulley's they have you covered. When I needed pulley advice they were helpful on the phone.
http://bouchillonperformance.com/BigBlockEngines.asp
