Idle solonoid #1165199
01/26/12 04:29 PM
01/26/12 04:29 PM
Finally a HUSKER again
Moparnut426 Offline OP
Is the idle solonoid really a needed item on a six pack set up? Just curious as to what it would do if anything on my build. I see many pictures on line and that is not in them.
Re: Idle solonoid [Re: Moparnut426] #1165200
01/26/12 04:39 PM
01/26/12 04:39 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Not "really" needed, but it sure helps stop the engine from rattling on after turning the key off! Without it, you may have to turn the key off "in gear"...
Re: Idle solonoid [Re: xs29j8] #1165201
01/26/12 04:49 PM
01/26/12 04:49 PM
Does it interupt the ignition or something?
Re: Idle solonoid [Re: Moparnut426] #1165202
01/26/12 05:17 PM
01/26/12 05:17 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
No, it allows the center carb to fully close when de-energized due to the ignition being turned off. When energized, the idle stop solenoid holds the throttle plates open enough to provide sufficient air to maintain idle speed. If no solenoid is used, the base idle setting has to be increased, and it does not "drop" when the ignition is turned off...
Re: Idle solonoid [Re: xs29j8] #1165203
01/26/12 05:28 PM
01/26/12 05:28 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Re: Idle solonoid [Re: xs29j8] #1165204
01/26/12 05:32 PM
01/26/12 05:32 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Re: Idle solonoid [Re: xs29j8] #1165205
01/26/12 05:39 PM
01/26/12 05:39 PM
Honestly looks like a decent deal to have hooked up. I like that bulletin, pretty basic and good info there.
Kasey
