Driveshaft Balancing - Dallas/Fort Worth
#116505
09/07/08 11:10 AM
09/07/08 11:10 AM
CrazyD
Re: Driveshaft Balancing - Dallas/Fort Worth
[Re: CrazyD]
#116510
09/07/08 06:25 PM
09/07/08 06:25 PM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
There are at least a couple shops in FTW, too: Fort Worth Gear & Axle - www.gearandaxle.com3409 Kelli Ct, Fort Worth - (817) 625-8878 American Drive Train 2519 NE 36th St, Fort Worth - (817) 831-7878 I haven't personally tried either one, but need to have that same job done some time soon. Clair
[Re: CrazyD]
#116511
09/07/08 11:54 PM
09/07/08 11:54 PM
Posts: 18,157 Mass
DAYCLONA
Mass
any recommendations?
Don't know your location, but Keisler Engineering in Tenn,....has a state of the art 10,000 RPM shaft balancer,...most shops only run'em up to 3500 RPM....Keislers a sponsor here, if your looking for contact info?
[Re: CrazyD]
#116512
09/09/08 01:02 PM
09/09/08 01:02 PM
Posts: 227 Tennessee
rj8806
Tennessee
Do they balance with ujoints and slip yoke installed, or just bare driveshaft? Never had this done before - old driveshaft, just want to make sure it's balanced perfectly
Can't speak for them but most of us who do balance driveshafts, need the assembled driveshaft in order to do a correct balance. If you attempt to balance just the tube and then add the u-joints and slip yoke, the balance is going to be off because of the added weight.
Typically we don't balance anyones driveshafts except for those who bought our kit. We purchased our own driveshaft making machinery so we could control the quality of driveshafts that we send out with our kits. Our builder is a little backed up right now with our kits but if you get in a pinch, give me a shout and I'll see if I can work you in the schedule.
Richard Tech Support Keisler Engineering
