Re: Ford 8.8 Rear in 1971 Plymouth
[Re: Kern Dog]
#1164766
01/26/12 12:39 AM
01/26/12 12:39 AM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
If you have the 8.8 with discs, why not give it a run? There are driveshaft/u-joint work arounds, 8.8s are commonly swapped into Jeeps. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: CoDart]
#1164768
01/26/12 01:27 AM
01/26/12 01:27 AM
Posts: 198 Gainesville Fl
mphsmitch
Gainesville Fl
I put an 8.8 out of an 95 exployer and it fit perfect. I had to cut off the mounts that came on the 8.8 and add the mopar spring perches.I also had to have a custom driveshaft built. I have about 125.00 total in the rearend. This website was very helpful.http://www.therangerstation.com/tech_library/Explorer8_8.html
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
