Clutch fork travel
#1164259
01/24/12 08:56 PM
01/24/12 08:56 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
How much does the clutch fork need to move (at the end OUTSIDE the trans) to properly disengage a diaphragm type clutch? I am working on a hydraulic conversion as mentioned in a few other posts and I need a hard number.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Clutch fork travel
[Re: Bill MeLater]
#1164261
01/24/12 11:04 PM
01/24/12 11:04 PM
67Charger
Erda, UT
Fair enough. I am new to the world of 4 speeds, so I will eliminate a variable and ask for throw out bearing travel.
[Re: 67Charger]
#1164262
01/25/12 12:33 PM
01/25/12 12:33 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Enough to give you about .060" between the clutch disc and the pressure plate and/or flywheel. You will have to make a bump stop on the pedal to achieve this. I made my own set up too and used a diaphram style clutch. Does that make sense??
[Re: Cuda340]
#1164263
01/25/12 05:29 PM
01/25/12 05:29 PM
67Charger
Erda, UT
It does, but I am vainly trying to put the horse ahead of the cart. I Am working on a hydraulic system and in order to pick the slave, I need to know how much to move the bearing, which can then be used to calculate how much throw is needed on the outside of the fork. I don't have all the pieces in hand yet, just searching for info in the mean time.
[Re: 67Charger]
#1164265
01/26/12 05:03 PM
01/26/12 05:03 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
For any slave that you choose, you do not choose by travel but by matching bore size to your master cylinder. e.g. if your master cylinder bore is 3/4" then your slave should also be 3/4". M/C=1", slave=1" and etc... Pretty hard to find a slave that won't push the clutch fork the distance you need if you're retaining the stock clutch fork.
Here's some excellent reading that you will find very useful:
http://www.hurst-drivelines.com/files/Clutch_Linkage_Installation_Tips.pdf
