Noisy A833
#1163001
01/22/12 09:59 PM
01/22/12 09:59 PM
Posts: 16 New Zealand
Ande
New Zealand
I have just bought my first Mopar, its a 1966 Chrysler 300 with a stroked 440, 18 Spline A833 and 8 3/4 and I love it. The only issue I have is the the gearbox is really noisy in 1st, 2nd and 3rd but perfect in 4th, the noise sounds like gear on gear meshing and its intrusive. It shifts very well but but I dont want it to sound like a NASCAR in those gears. It is summer here, I have checked the oil level and topped it up with 80w / 90w as it had leaked slightly. I dont think the leaked oil was ATF (not red) Any thoughts?
Re: Noisy A833
[Re: Ande]
#1163003
01/22/12 10:15 PM
01/22/12 10:15 PM
Posts: 43,159 Bend,OR USA
Cab_Burge
One or more of the bearings are bad, sorry It could be the input shaft bearing,output shaft bearing or the needle bearings in the input shaft and or the needle bearings in the cluster shaft. I will bet it is in the cluster shaft needle bearings if it is ONLY noisy in 1st,2nd,3rd, and reverse, which all involve the cluster shaft driving the output shaft throught the gears being used reverse is NOT synchromesh or helical cut so it will alweays be noisy when backing up. One other thought is the input shaft bushing or bearing in the crankshaft being beat up or missing
Re: Noisy A833
[Re: Ande]
#1163005
01/24/12 11:44 AM
01/24/12 11:44 AM
Posts: 5,270 Missouri
MY340
Missouri
Try a 50/50 mix of Lucas Oil additive and 80/90 wt gear oil to see if that helps. My old Duster 340-4spd was noisy on upshifts but that mix really quiet it down. It had ATF in it previously when I bought the car. Original 4-spd with 92,xxx miles and it never gave me any problems.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
Re: Noisy A833
[Re: Ande]
#1163006
01/24/12 11:54 AM
01/24/12 11:54 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Yeah, tear it down ASAP. If you keep driving it, broken teeth are a distinct possibility.
Not hard to rebuild (but, OK, I've been doing 'em since '65...)
Rick E.
Re: Noisy A833
[Re: Ande]
#1163008
01/25/12 01:27 PM
01/25/12 01:27 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
Thanks Rick, its beyond an oil change I will take it out this weekend. Any recommended rebuild kits? I have contacted Passon and Brewers, both of them will freight to me here in New Zealand
both are good, be sure to talk to them about what trans they have as they have different input bearings, syncros etc... just to be sure you get the right parts the first time.
To be sure because shipping ins $$$, pull the side cover off and send some pics to them - they should be able to ID what you need right off the bat. You can pull the cover off in the car (drain the oil first)
Re: Noisy A833
[Re: Ande]
#1163009
01/25/12 01:43 PM
01/25/12 01:43 PM
Rick_Ehrenberg
Marlboro, NY, USA
You should probably disassemble it first. Might just need one bearing (the center bearing on 23-spline trannys is what I always failed...) or might need a lot more.
I was gonna be changing planes in Auckland in March, could have had a heavy carry-on... ;-> (Decided to go NYC-LAX-MEL, going to Chryslers on the Murray, Wodonga, Victoria, Australia. Wanted a 747, not A380).
Rick
Re: Noisy A833
[Re: Ande]
#1163010
01/25/12 03:16 PM
01/25/12 03:16 PM
Posts: 4,285 Ohio
64dodge572
Ohio
As others have mentioned I would take the trans apart so you will get all the parts you might need in one shipment. Here is some helpful info for identifying exactly which trans you have.
http://www.brewersperformance.com/orderinfo.htm
Any questions just let me know.
Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
Re: Noisy A833
[Re: Ande]
#1163014
01/25/12 07:16 PM
01/25/12 07:16 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Just sent you an email. Let me know if you didn't get it.
Dan
Re: Noisy A833
[Re: Ande]
#1163019
01/27/12 09:32 AM
01/27/12 09:32 AM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
I was going to pay a local gearbox guy to do the rebuild but I'm starting to think that I could save some real $$ and learn something by doing it myself. Thanks for all the help and friendly advice
Find a good shop manual if you don't have one. Also get a dummy shaft for your cluster gear or make one from a wooden dowel rod. You'll also need a bearing splitter and some snap-ring plier and a shop press. Its not a tough job at all. You can do it. The press work you can farm out to a local auto machine shop. Just don't waste your summer down there
