My car is a Duster, the hood overhang from the radaitor support to the front of the hood is very similar, at least on my 1969 Dart GTS
I hope you can see the supporting tube bracket welded onto the radiator support holding the front of the middle two Dzuz faterner brackets
The paasenger side Dzuz bracket is pop riveted on
, The driver sides is bolted on with 1/4 inch bolts, flat washers and nuts
I had the hood mounting brackets done so I will redo the passenger side with 1/4 bolts, washers and lock nuts, hopefully this winter
