Re: Race gas versus e-85
[Re: racerx]
#1160909
01/19/12 10:21 PM
01/19/12 10:21 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Mine slowed down due to lack of traction. Got that figured out and it was to late in season.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1160910
01/19/12 10:49 PM
01/19/12 10:49 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
any forcasts on the future of E85? the subsidies ended, right? does that mean it's going away? or is the price of it going to skyrocket now?
how can they expect to keep it on the market when it's going to cost the same or more than regular gas, but gets lower mileage on the daily drivers it was originally intended for?
**Photobucket sucks**
[Re: 70Cuda383]
#1160911
01/19/12 10:58 PM
01/19/12 10:58 PM
1967dartgt
Hilltown Pa
I heard that there is 1200 new pumps going in over the whole country. I hope it doesn't go anywhere.
[Re: 69dart]
#1160913
01/20/12 12:36 AM
01/20/12 12:36 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
The ethanol industry is making a profit, and are not having problems without the subsides. Now if the US government would quit susidising foreign oil, then we'd be set.
I'm not worried about the lack of government help shutting down ethanol. I'm more worried about the bad info the tree huggers, and big oil are pouring into the general public, about ethanol, food prices, and feeding the world.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: 69dart]
#1160914
01/20/12 12:37 AM
01/20/12 12:37 AM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
They are still adding new pumps here in Ohio so I hope its here to stay.
The price has stayed at $2.89 since November.
Are you allowed to run E85 in Nostalgia super stock?
[Re: racerx]
#1160916
01/20/12 01:43 AM
01/20/12 01:43 AM
Posts: 52,972 Romeo MI
MR_P_BODY
When I changed over to e-85... my car ran exactly the same times.... within a few thousandths, same 60' at 1.20.... but all this for a lot LESS fuel cost... I went from 112 octane to e-85 so the price difference was pretty big... I've been VERY happy with it
[Re: MR_P_BODY]
#1160917
01/20/12 05:00 AM
01/20/12 05:00 AM
Posts: 4,070 Mo.
racerx
Mo.
I was thinking that with the increase torque that e-85 produces that one would see a better 60'with every thing being equal so then i must ask where do uall see the increase, is it through out the rpm range?
[Re: racerx]
#1160918
01/20/12 10:19 AM
01/20/12 10:19 AM
MR_P_BODY
The only increase I seen was in consistency... I was set up to run 10.0 and made 8 passes all within .008 for a total spread... I did make a few passes that were in the 8s and that could have been fuel or the DA or both
[Re: 70Cuda383]
#1160919
01/20/12 04:36 PM
01/20/12 04:36 PM
Posts: 16,925 NC
440Jim
NC
Let's be clear, the ethanol industry was not getting subsidies, the blenders were getting the credits and that was typically an oil company that blended 10% ethanol into their gasoline.
So I don't expect the price of ethanol to be significantly affected by the change in the tax law. That being said, ethanol's price moves with the price of gasoline due to market forces. So if gasoline goes up (oil prices, etc), then so will the pump price of ethanol. It would help ethanol prices at the pump if more infrastructure was in place for ethanol like it is for gasoline; specifically pipe lines (but the current US President is against building any pipelines...)
I would like to see the motor fuel tax eliminated for high percentage ethanol fuels (say 70% and higher) as well as other renewables/biofuels. Keep the tax where it is for petroleum based fuels (but I am against taxes in general).
[Re: 1967dartgt]
#1160921
01/21/12 08:18 PM
01/21/12 08:18 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Hope they put some in out here in the Coachella Valley. Closest e-85 is about 50 miles away. Kind of a deterrent.
With all the sand guys out here, seems like a possible market spot.
[Re: StillRock69]
#1160922
01/21/12 08:28 PM
01/21/12 08:28 PM
Posts: 37 Wisconsin
StillRock69
Wisconsin
Yes, in National Muscle Car Association and Nostalgia Super Stock National Association events
1.6 GASOLINE GASOLINE: In the NSS classes, common and commercially available racing gasoline, pump gasoline and E85 are the exclusive (only) fuels or blend of fuels permitted. Under no circumstances can the maximum volume of alcohol exceed 85 percent. 1.8 ALCOHOL ALCOHOL: Permitted in the FX classes.
[Re: RobX4406]
#1160923
01/21/12 08:32 PM
01/21/12 08:32 PM
dartman366
Mt. Vernon, Ohio
been concidering the change myself, and one of the deciding factors is availability, no pumps here in MtVernon so I have to drive to Newark or Chesterville, little over an hour round trip north or south of here.
[Re: 69dart]
#1160926
01/22/12 02:09 PM
01/22/12 02:09 PM
Posts: 3,428 Dandridge TN
Dabee
Dandridge TN
You can pick up a left over 55 gallon drum at the track and a hand pump for $15. I filled my drum up when prices bottomed out in October. It wasn't quite E85 (tested 78) but I've heard you can add a couple gallons of Methanol to get it back to E85. Has anyone tried this?
I do it all the time. All they sell here is E-70, so I add Meth to bring it up to EM-85. Works great. I tune my AFR to .85 LAMBDA under power. I check it as soon as I'm in high gear going down the track or just before crosseing the strip.
[Re: Dabee]
#1160927
01/22/12 06:12 PM
01/22/12 06:12 PM
Posts: 4,070 Mo.
racerx
Mo.
So is that how u come up with em-85?Is this stuff u call meth Alcohol...Thax
