Re: 1969 Hemi Coronet R/T restoration
[Re: ]
#1159271
11/02/13 01:06 PM
11/02/13 01:06 PM
full front pan, both rear pans, rear under seat pan. All AMD.
[Re: ]
#1159272
11/02/13 01:08 PM
11/02/13 01:08 PM
one piece trunk floor, trunk drop offs, all AMD
[Re: ]
#1159273
11/02/13 01:11 PM
11/02/13 01:11 PM
We have quarter panels! Both left and right quarters, inner and outer wheelhouses, dutchman panel, tail panel and trunk gutters. All AMD
[Re: ]
#1159274
11/02/13 01:13 PM
11/02/13 01:13 PM
Here is the right side, everything assembled well. Gaps are good with the only fitment issues being the trunk drop offs and the tail panel. All is well now though.
[Re: ]
#1159275
11/02/13 01:20 PM
11/02/13 01:20 PM
Here is where we were having some issue getting the tail panel to fit how we wanted. Apparently the tail panel was not countoured enough to fit into the pocket stamped into the quarter panel flange. All is well now. Car also recieved a rear crossmember, crossmember extensions, bumper bracket reinforcements, shackle hanger frames, trunk latch bracket, spare tire bracket and both front inner fenderwells. All AMD and all bought at Mike Rhiel's Roseville Moparts.
[Re: ]
#1159276
11/02/13 01:22 PM
11/02/13 01:22 PM
I should have some better quality pictures up of the body next week. Hopefully it will be in fresh epoxy primer at that point. BTW, the Hemi is at the machine shop right now too.
[Re: OhioMopar]
#1159278
01/05/14 09:33 AM
01/05/14 09:33 AM
Well, the body work is underway, but I havent had time to swing by and take any pictures yet. I am told from the body man that everything is moving along well. I ended up finding an original ramcharger hood for the car that I will be using, so I will be looking to off the converted hood that I initially bought.
Other than that, the machine worked was done to the hemi and my brother was kind enough to pick it up for me. I would have picked it up myself, but I was too busy sliding into a cement barricade with my Ram
[Re: ]
#1159279
01/05/14 09:36 AM
01/05/14 09:36 AM
[Re: RSNOMO]
#1159282
01/05/14 01:24 PM
01/05/14 01:24 PM
That block ridin' in the back of a GM pick-up???
What gave it away? The ram head on the bedliner? C'mon man, you know that is a 05 Ram Daytona!
[Re: 1968beepbeep]
#1159284
01/06/14 07:06 AM
01/06/14 07:06 AM
Posts: 3,363 DTW
drmopar
DTW
GM Truck? Come on. I would only expect that from Rob Sharon...
-------------------- RM27H9G 4 speed F8/tan guts RS27L9G auto B5/black guts WM23H9G auto F5/green guts 2021 Challenger 392 Indigo/black guts 2019 Charger Daytona R/T F8 on black 2018 Ram Sport Hemi 4x4
[Re: drmopar]
#1159285
03/08/14 12:37 PM
03/08/14 12:37 PM
Bodywork is well underway. All of the leaded seems are done and the blocking of the roof has begun with the car on its side on the rotisserie. Coming along well so far. All the bolt on panels are pretty much done and after buying 3 hoods, I finally have one the bodymenare willing to use, so that is next on the agenda. Here are some pictures from a few days ago. I am still chipping away at some small parts in the meantime.
[Re: ]
#1159286
03/08/14 12:38 PM
03/08/14 12:38 PM
[Re: ]
#1159287
03/08/14 12:40 PM
03/08/14 12:40 PM
buddy seat brackets in place.
[Re: ]
#1159288
03/08/14 12:42 PM
03/08/14 12:42 PM
Getting ready to start drilling the finish panel holes in the AMD tail panel.
[Re: ]
#1159289
03/08/14 12:43 PM
03/08/14 12:43 PM
Decklid getting its second block session before starting on the hood.
