neutral safety switch? #1157383
01/14/12 07:45 PM
01/14/12 07:45 PM
Ambridge, Pa.
rickraw Online content OP
rickraw  Online Content OP
Ambridge, Pa.
hey everyone. has anyone wired a switch to a b&m ratchet shifter. it has 2 switches inside it- 1 for reverse lites, which i'm using, the other for nuetral start. switch in shifter only has 2 terminals. can't use factory switch cause strap from trans shield covers the terminals. thanks fir ur time. seeya.
Re: neutral safety switch? [Re: rickraw] #1157384
01/14/12 08:50 PM
01/14/12 08:50 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Yes I have done the exact same thing. I wired the switch so it provides ground for a relay.
Re: neutral safety switch? [Re: rickraw] #1157385
01/15/12 02:33 PM
01/15/12 02:33 PM
NC
barracuda man Offline
NC
I have mine wired on the b&m switch.It's mandatory in IHRA drag racing.I did see a guy at are local trac without one crank his car in gear and hit the car in front of him.neither car could race the next round. hope this helps.
