Re: FBO VAcuum Adavance Distributor?
[Re: YO7_A66]
#1153877
03/13/12 03:47 AM
03/13/12 03:47 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
So how do you like it after having it for a bit? I've been considering taking the plunge for my wagon rather than monkey with my existing dizzy...
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Secret Chimp]
#1153878
03/13/12 07:32 AM
03/13/12 07:32 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I have not been able to drive it yet but it should lean out my cruise numbers (currently 30mph to 60mph 14.2-14.6 A/F) without any other carb changes. My decel A/F ratio was dropping down around the 13.0 mark and this should lean back out too. the only difference so far is that I have gained 1"hg in N and 1/2" in D and the idle and the vacuum is SOLID/STEADY.
Our weather just turned so hopefully I will start to get some time driving it soon.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Joshs68]
#1153880
03/13/12 09:28 AM
03/13/12 09:28 AM
YO7_A66
Indiana
The distributor that I pulled out was a FBO unit with no vac advance that I have run for the last six years. It is now my backup unit.
[Re: YO7_A66]
#1153881
03/15/12 01:02 PM
03/15/12 01:02 PM
YO7_A66
Indiana
I need to clarify something that I stated about the FBO vacuum distributor. I wrote that FBO puts a lower rated can in the dist and this is incorrect.
I asked FBO to tell me what rated can they use and this is their reply: ""There is no "Rating", we install limiters in the vac can to make it do what we want.""
I don't know how they do it, but I like what it does. Sorry for the inaccurate statement that I wrote.
[Re: YO7_A66]
#1153882
03/15/12 03:36 PM
03/15/12 03:36 PM
Posts: 1,647 IL
71383beep
IL
i just pulled mine and am gonna send it to him for this as well. I like the idea of additional timing during idle and low throttle.
I have his original ignition setup, his recurved non-VA dizzy, and a 650 Mighty Demon prepped by him and have been very happy with all of them.
Keep up with the posts and let us know how your tuning is going.
'73 GK6 Challenger Rallye - 340 4-Speed
