Re: Anyone running the 426 gen III crate motor yet?
[Re: 440forPOWER]
#1151534
01/07/12 01:44 AM
01/07/12 01:44 AM
Posts: 4,255 Canada
WO23Coronet
Canada
ZIPPY (a member here with inside knowledge ) did say that the 392 crate engine put out alot more power with the Drag Pack intake (supper tall 4bbl manifold)vs the factory intake, to the tune of almost 60 HP I think, although they were rated the same. I think the 392 was rated at the same 540 hp the 426 is. For the price it seems like a great deal, but if you're going to pull the trigger on one it might be worth getting it with the Drag Pack intake
[Re: MuuMuu101]
#1151538
01/07/12 04:10 PM
01/07/12 04:10 PM
Posts: 189 Portland,OR
rjsjea
Portland,OR
A small red flag that seems to be going off in my head is that in both the links there are no reference of the intake manifold (carbureted/fuel injected), driveline accessories (PS, AC, Alternator, etc if you choose to use them), or anything about the computer system and harnesses (if you decide to go EFI). Those alone are going to cost you some big money.
Front end accessories are about $1k (AC,PS,Alt,tensioner,hardware) from Bouchillon Perf. Or it would be cheaper to delete some options there, obviously.
The efi controller and harness is $2,580 from the guys posted above.
I am almost sure the motor comes with the efi intake, billet fuel rails/regulator as pic'd.
[Re: rjsjea]
#1151540
01/07/12 07:47 PM
01/07/12 07:47 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I was going to recommend Bouchillon Performance because they have the entire kit and experience for Gen III swaps but their 426 is more expensive (I believe $17k or so with less horsepower and torque).
http://bouchillonperformance.com/G3HemiCompleteEngineKits.asp
[Re: Dragula]
#1151541
01/07/12 08:16 PM
01/07/12 08:16 PM
rjsjea
Portland,OR
Why go with that one, when these are half the price?
http://www.indyheads.com/oldschool.html
The first one posted is the new aluminum block *100Lbs lighter*, has about 150 more hp/tq. Also EFI, if one considers that a benefit.
But I agree that one should be considered for someone looking for a carbed GenIII motor.
