Re: 1969 Barracuda M code
[Re: RoadRunnerJD]
#1149373
01/21/13 09:49 PM
01/21/13 09:49 PM
Posts: 21,501 N.E. OHIO, USA
A12
N.E. OHIO, USA
Little off topic but that photo reminds me of an interesting point. The Cuda 440 is in the same NHRA class as the A12's! Anyone hear of or know a T5 Cuda 440 coupe from up around Syracuse, NY or points thereabouts?
Syracuse, NY area must have been M-Code Central....My A12 rr was originally sold in Baldwinsville, NY just out side of Syracuse and I know of four more M-codes from there and some very unusual colors?
[Re: big-block-dave]
#1149377
03/16/13 01:33 AM
03/16/13 01:33 AM
A12
N.E. OHIO, USA
Is this statement even close to being true that "only about 30 M-Code Darts still exist": Assembled as a run-of-the-mill 383 car, then transformed into a 440-powered strip streak by the Hurst-Campbell Corporation, this Dodge is one of only 640 M-code Darts produced for the 1969 model year. Most of those big engine warriors were sold to drag racers who needed something tough to whip at the track and, as a result, Chrysler expert Galen Govier estimates that only 30 still exist.
[Re: A12]
#1149378
03/16/13 05:07 PM
03/16/13 05:07 PM
Posts: 511 AZ.
696pack
AZ.
Assembled as a run-of-the-mill 383 car, then transformed into a 440-powered strip streak by the Hurst-Campbell Corporation , this Dodge is one of only 640 M-code Darts produced for the 1969 model year. Most of those big engine warriors were sold to drag racers who needed something tough to whip at the track and, as a result, Chrysler expert Galen Govier estimates that only 30 still exist.
There are so many things wrong with the above bolded remarks.
1. Not much "run of the mill" about a 383 A body and were available and sold through the 1969 model years but few were sold in comparison to a true "run of the mill" Dart or Cuda.
2.Transformed by Hurst-No.
3. There was a progression for big block A bodies and it goes like this:
In 1967 Mr. Norm complained that the competition had a leg up on Mopar in our A body size cars and asked for a 383-4 Dart. Factory said it would not fit in current configured body. Weeks later Norm shows up in Detroit with a 383-4 powered Dart they built @ the dealership. They show it to engineering and they start building them.
Next year Norm asks for competition for the 396/375 Chevy Nova. Factory says if you buy 50 or more they will build them. Norm agrees and replaces the GTS emblem with another S in place of the T and calls the car a Grand Spalding Sport.
The ONLY A bodies that Hurst had anything to do with were the 1968 Hemi Darts and Cudas because they had too many modification to perform on the assembly line, so unfinished cars were sent there for completion.
ALL 1969 M code A bodies were build completely @ the factory assembly plant. They did "begin" as a 383 car on PAPER just as the 1969 A12 cars did but never had a 383 ACTUALLY installed in the car. This is why BOTH of these "package cars" use an M in the V.I.N. Package cars were expected to be limited production and they did not create a new engine code for the V.I.N. and rather created an option package with an assigned sales code listing specific equipment INCLUDING the engine to identify what the actual engine is. The V.I.N. just shows "special engine" for the M code. You have to refer to the factory sales code for the car to determine what engine the car actually has.
[Re: vette1986]
#1149381
03/16/13 08:22 PM
03/16/13 08:22 PM
A12
N.E. OHIO, USA
Good info but what about there being "fewer than 30 M-code Darts left out of the 640 built?"
There are more than that registered on the gts registry, shoot we had two of them at one time and just sold one. They were beat to death and not alot survived compared to other cars like the a12's or e bodies which were "more valuable" cars. Come on its an A body it can't be value able can it?? They are actually one of my favorite mopar as they were just meant to be nasty from day one. Too bad you could not get a 4 speed with them as I am sure a 4 speed with a set of slicks would probably been the fastest true production mopar of all time. Can't count the hemi darts and cudas as they were never really meant for the street.
Didn't get the 4-speed because there wasn't a Dana that would fit under the '69 A-body.
[Re: 6bblgt]
#1149383
03/16/13 08:31 PM
03/16/13 08:31 PM
A12
N.E. OHIO, USA
I actually think it's the opposite - there are a lot that survive due to the fact that they ended up as track cars & weren't ravaged by salt in the midwest VS. cars that could still be used as "drivers".
I'd bet there are 30 factory 440 Dart GTSs still being used as racecars.
I know where there's one......
[Re: A12]
#1149384
03/16/13 08:35 PM
03/16/13 08:35 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
& some racers don't play well with registries!
