open or muffled headers? #1148532
01/02/12 12:06 PM
01/02/12 12:06 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
i have a set of tti's 1" 7/8,(not the best) i want to know if its a bad idea to bolt a race muffler (kooks or arh type) directly to the flange,i've seen it before i just dont know if its good or bad..i do listen to advice so any would be good.I also was thinking open headers,i'd rather muffled though.
Re: open or muffled headers? [Re: fishy340] #1148533
01/02/12 12:14 PM
01/02/12 12:14 PM
ill
dennismopar73 Offline
ill
we have done this before with no ill effects , a jetting change was needed as well, also small timing change
Re: open or muffled headers? [Re: fishy340] #1148534
01/02/12 12:23 PM
01/02/12 12:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
most header mufflers hang kinda low. They have to clear the floor of the car. Are you running a muffler class? might be better to clear the bend and hang a set of Moroso Spirals with turn outs on them.
http://www.summitracing.com/parts/MOR-94050/
Coming soon!!!!
Re: open or muffled headers? [Re: fishy340] #1148535
01/02/12 01:49 PM
01/02/12 01:49 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
if u bolt to the flange, i'd support the muffler some how to keep the headers from flexing. they may crack from the weight.seeya
Re: open or muffled headers? [Re: rickraw] #1148536
01/02/12 03:06 PM
01/02/12 03:06 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Andy,remember the 3 chamber rule at Englishtown I went with the hooker aerochamber which is a straight through muffler available up to 3.5 inches last time I looked
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: open or muffled headers? [Re: hemi-itis] #1148537
01/02/12 05:23 PM
01/02/12 05:23 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Those are what I run. They do look like a straight through but they are chambered. Been 135mph through them kind of heavy though if you ask me.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: open or muffled headers? [Re: fishy340] #1148538
01/02/12 07:12 PM
01/02/12 07:12 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
after talkin w my man,i think im gonna try what i have now full exhaust& at the track unbolt and rejet to see if it picks up,gonna be wild ride either way,I do know w the exhause off i'll lose 50lbs + i gotta lose 15 im 220 now lol.
Re: open or muffled headers? [Re: fishy340] #1148539
01/02/12 08:31 PM
01/02/12 08:31 PM
Locomotion Offline
Locomotion  Offline
FWIW, I have a 360 with TTI step headers - 1 5/8"-1 3/4" - which I ran open for a couple of years. Then I added a 3" X-pipe and Dynomax Ultraflow mufflers dumping at the rear end housing. I removed the 60lbs the exhaust added to bring it down to the same weight as before and the car was .05-.10 faster!
I figure that the mufflers didn't hurt at all and the X-pipe helped on my particular combo. I may go to their bullet version to save a little weight and gain a little more room around the rear end housing.
Re: open or muffled headers? [Re: fishy340] #1148540
01/02/12 10:55 PM
01/02/12 10:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Fishy is this for the new bullitt?And how much is it weighing now?........
Re: open or muffled headers? [Re: racerx] #1148541
01/03/12 05:48 PM
01/03/12 05:48 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
tiny bit over 3000 w 727tf,putting in ati supercase glide,and yes its for the same motor,different set up though...i have a x pipe on it now w ultra flows,3"...im not a huge fan of the open headers,but i'll try it. thanks
Re: open or muffled headers? [Re: fishy340] #1148542
01/05/12 11:18 AM
01/05/12 11:18 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I hear ya. put mufflers on that sucker and let it eat
Re: open or muffled headers? [Re: racerx] #1148543
01/05/12 12:16 PM
01/05/12 12:16 PM
hemi-itis Offline
hemi-itis  Offline
My 4 inch system is a pain the DIFF to remove.I doubt it would make that much of a difference other than the weight removed
