Early B insulation pins shorter #1145807
12/28/11 02:31 PM
12/28/11 02:31 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I was comparing some OEM insulation pins to originals so I grabbed a pin from a bag I have labeled "63-65 B body insulation" and the pin was .400" SHORTER than all the Mopar insulation pins I have seen before.
Is this a 65 and earlier thing?
Re: Early B insulation pins shorter [Re: 71TA] #1145808
12/28/11 02:46 PM
12/28/11 02:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Jim,
Are you now making these pins? pm if you prefer.
there is also an all rubber version that I believe is 73 and later and they look nothing like these plastic pins
