Any Ideas on painting/dying fuel lines, hoses, etc?? #1144018
12/25/11 06:03 PM
12/25/11 06:03 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Does anybody have any ideas or tips on the best ways to paint or dye rubber fuel lines or hoses?
I have some ideas on how to make a stencil with the correct "KV" letters spaced the same as the original hose. I'm not sure about the best way to "paint" the KV on. Would white aerosol vinyl dye be best? Since my Duster 340 has the ECS system I'm looking for a cheaper alternative to the correct looking "KV" stenciled hose.
Re: Any Ideas on painting/dying fuel lines, hoses, etc?? [Re: NV69B7RR] #1144019
12/25/11 08:45 PM
12/25/11 08:45 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
A member on the board here could help you, handle is LemonTwiist.
Re: Any Ideas on painting/dying fuel lines, hoses, etc?? [Re: rayztoy] #1144020
12/26/11 01:19 AM
12/26/11 01:19 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I thought they were a faded yellow?
Re: Any Ideas on painting/dying fuel lines, hoses, etc?? [Re: astjp2] #1144021
12/27/11 01:21 PM
12/27/11 01:21 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks RAZtoy!
Re: Any Ideas on painting/dying fuel lines, hoses, etc?? [Re: astjp2] #1144022
12/28/11 02:34 AM
12/28/11 02:34 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Faded yellow = dirty white?
Re: Any Ideas on painting/dying fuel lines, hoses, etc?? [Re: astjp2] #1144023
12/28/11 09:32 AM
12/28/11 09:32 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've never seen any of the KV fuel line in anything but white print.
This is an nos piece I've had for years. And there is no doubt, it's white.
with flash
Re: Any Ideas on painting/dying fuel lines, hoses, etc?? [Re: gtx6970] #1144024
12/28/11 09:34 AM
12/28/11 09:34 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
without flash
Also be careful what you use for the print.
It takes special ink to adhere and dry on rubber.
