need a machine shop in the bay area (ca)
#1143340
12/24/11 04:08 PM
12/24/11 04:08 PM
Posts: 781 wine country
8urvette
wine country
I am in the process of swapping 68 barracuda with a rb from auto to manual. i pulled the drivetrain in order to do it. while the motor was out i noticed oil seepage from the oil pan between the block and the girlde. so i pulled it apart and resealed it and did new gaskets along with. it sat a few weeks and i noticed its still seeping oil!!!! so i pull it and after talking to few mopar guys they say to use a gasket between the girlde and the block, ok fine ill try it. When i get into it this time i notice my rear main seal has tiny bit of seepage... fine ill replace it. since the engine is out and i wont be driving it any time soon i decide might as well pull it all apart and do new gaskets throughout the engine. when i start pulling rods i do #1 first- spun rod bearing I had no idea!!!!! the engine has a huge cam and 3.5 inch dyno max bullets on it i had never even heard it! the motor ran great and i could get it to idle at 800. and rev quickly to 7000... the bearing looks burnt, and is loose inside the rod, the crank has some very minor scoring on it. I need a reputable, honest, machine shop preferably in the north bay area of CA. from sacramento to sf, prefer to not have to go to san jose. the motor has low-ish miles on it, and my best guess is the external oiling system drained out after letting it sit a week, if it sat any longer than one week i would pull the dist. and prime the system hit the starter to turn it over and re-primed. so, whats the best honest, reasonable, accurate shop around. yes its all 440 source stuff, but i had the crank polished when i got it, all rods were re-sized.... i spent close to 2000 on block prep and parts prep. makes me wonder if that shop wasn't so good....
Re: need a machine shop in the bay area (ca)
[Re: Jeepmon]
#1143345
12/25/11 05:43 AM
12/25/11 05:43 AM
Posts: 19,368 Las Vegas
Al_Alguire
Las Vegas
LJ's always treated me right..But IMO Jason Pettis at Pettis Performance is more than worht the trip to Hesperia.
[Re: WheelsUp73]
#1143351
12/25/11 04:14 PM
12/25/11 04:14 PM
Al_Alguire
Las Vegas
Bailey brothers is a great place as well. Was just always a bit busy and slow for me. John at LJ's can be an interesting guy,. He has always done right ny me however. IMO everyone up in NorCal is a bit on the expensive side. Kind of why I recommend Jaons at Pettis. His prices are better and you will be hard pressed to fnd a guy with better knowledge on how to make power. Price is the reason I started using his servies and now he is my guy no matter where I live. Nice to have him a lot closer now though.
[Re: 8urvette]
#1143352
12/25/11 04:32 PM
12/25/11 04:32 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
..........the bearing looks burnt, and is loose inside the rod, the crank has some very minor scoring on it.
Sorry to hear that. Do you think oil drainback after a week would lead to all that? Sounds like there might have been some dirt/metal in the oil passages, a rod knicked the crank when being assembled or something else along those lines.
Did you modify/ open up the block oil passages?
At this point, I'd take it to where Al and Jeepmon recommend.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 8urvette]
#1143353
12/25/11 07:18 PM
12/25/11 07:18 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
are any of these guys reasonable with prices?
The one thing I found when looking at machine shops, those that are in the actual BAY AREA are priced a heck of a lot higher than those in the surrounding areas..
has anyone heard of S&S automotive in san leandro?
Their prices were one of the most expensive and and the customer service guy on the phone pretty much turned me off with his lack of caring and I felt that he pretty much told me that the shop was too busy for me and my little mopar motor..
I still did search out recommendations for them and found mostly positive comments, but it seemed to me that they were more focused on high horsepower Chevy stuff..
In closing.. it pretty much boils down to which machine shop will show patience to get your stuff done right.. willing to listen to you and your wants and needs.. get the stuff back to you when they tell you they will and finally be an affordable shop... That right there is Valley Balancing in Ceres..
[Re: jbc426]
#1143354
12/26/11 03:18 AM
12/26/11 03:18 AM
8urvette
wine country
"Sorry to hear that. Do you think oil drainback after a week would lead to all that? Sounds like there might have been some dirt/metal in the oil passages, a rod knicked the crank when being assembled or something else along those lines.
At this point, I'd take it to where Al and Jeepmon recommend."
after talking with a few fellow racers, i remember taking my crank and rods back to the machine shop b/c when i used plastigauge it showed that some of the clearances were a bit on the snug side, (i don't remember what they actually were). The machinist mic'd everything in front of me and we did the math, it all specced out. he claimed that plastigauge isn't accurate as his calipers. i believed him, now im being told it the exact opposite. so it has me wondering if my clearances were too tight... either way it looks like im spending more money.
how are MEW prices? being they specialize in mopar i expect them to be very pricey, no?
who is pettis??
[Re: 8urvette]
#1143355
12/26/11 02:14 PM
12/26/11 02:14 PM
Al_Alguire
Las Vegas
Who is Pettis is easy. He is one of the top engine builders on the west coast in my opinion. Attend any heads up event out here, PSCA SCSN or WCHRA and you will see his name on many of the fastest cars. He also has built a few Mopar stockers that work pretty well. As for how to get it touch here he is at http://petisperformance.comThey are a small shop. The phone is usually answered by his mother or father. He is fairly busy as well but he is also ver meticulous and builds a few Mopars. My B1 in on his website when it was originally done. We have sincs had it freshened up and added some ponies. I have been very happy with Jason's work. He aslo comes by at the track to see if we need any help or if there is anything he can do for us.
[Re: Dduster]
#1143357
12/26/11 02:59 PM
12/26/11 02:59 PM
Al_Alguire
Las Vegas
Obviously he only comes by if he is at the track I am not a local track racer as most know we do travel and come across Jason at all the aforementioned associations. jason does do just machining as well. He has done a number of things for me. Still a three plus hour drive for me to his shop but worth the money.
[Re: Dduster]
#1143358
12/27/11 12:07 AM
12/27/11 12:07 AM
8urvette
wine country
If this guy's underwear is getting tight over oil pan oil leaks he may not be happy with anyone regardless to cost?
so judging by this comment your the guy who leaves oil spots down the track... let me be the first to thank you for the many hours lost waiting while they have to re-prep the track.
anyways... thank guys , illl be contacting S&S and MEW as soon as they open back up, MEW is closed till jan. 9th.
