Re: 1998 dodge ram v10 fuel filter
[Re: JRMOPAR]
#1143076
12/24/11 10:41 AM
12/24/11 10:41 AM
Posts: 1,089 st.cloud fl
d-150
Smarter than a 5th grader?
st.cloud fl
[Re: upnover]
#1143078
12/24/11 12:56 PM
12/24/11 12:56 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Its part of the pump unit. There is a primary filter on the bottom that could be a nylon screen or a round paper unit. Then there is a secondary unit on top thats silver which is what the fuel line hooks to. This is also the pressure regulator. To do them, the pump needs to come out. If you have some miles on it, you would be better off replacing the pump module instead of just the filters [ the nylon unit can't be replaced anyway]. Also put a new fuel pump relay in. If the old one is sketchy, it will take the new pump out due to lack of voltage. I learned this the hard way. I'm more inclined to think you need to clean the throttle body and A.I.S. or I.A.C. motor since these being dirty will cause stall issues too. Get a tb gasket, some Berrymans and an old toothbrush and have a scrub party.
Carl Kessel
[Re: JRMOPAR]
#1143080
12/24/11 03:08 PM
12/24/11 03:08 PM
Posts: 397 Ozona, Texas
Paladin
Ozona, Texas
JR,
Unless you have uncommonly good luck when placing a bet, why don't you see if you can locate a scan tool and see what it tells you? I bought my V10 some six months ago, and the first two purchases made for it were a scan tool and a shop manual.
With these newer vehicles these two items are a must have in both cost effectiveness as well as time and effort expended.
Hope the problem is found quickly and easily repaired.
Merry Christmas,
Paladin
1971 Dodge Charger R/T 1977 Chrysler Cordoba A35 1979 Dodge Lil� Red Express 1981 Chevrolet Corvette 1985 Chevrolet Corvette 1986 Chevrolet Corvette Roadster 1994 Lincoln Mark VIII 1998 Dodge Ram 2500 Sport V10
