Hey I got the same kit from summit and had the same problem. What I found was that one of the piston seals were pulling the piston back to far when releasing the pedal. It was pulling back .090
from the pad. The seal was some how twisted when it was assembled. Was in the same situation you have. After multiple phone calls and e-mails, Got the caliper replaced and works great.
I know, The bleeder is on the bottom in the picture but the directions and the tech support said to install this way. There is a bleeder in the banjo fitting on the line.
