What's different 70-71 vs 72-74 Wiper motors #1142755
12/23/11 09:58 PM
12/23/11 09:58 PM
BDW Offline OP
BDW  Offline OP
Looking at RockAuto, the 72-up wiper motors are $40.
70-71 is not available, and from what I can tell it's >$300 to get rebuilt.
Anyone know what the difference is, and if the later part can be modded to work?
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #1142756
12/23/11 10:19 PM
12/23/11 10:19 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
I have ran into the same issue I also need one for a 70. From what I was told the difference is that they park in a different place. The 70 will park lower for a hidden wiper effect. But I do not now for sure if this is true.
Re: What's different 70-71 vs 72-74 Wiper motors [Re: magiccuda] #1142757
12/23/11 10:28 PM
12/23/11 10:28 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
For what model? 2-sp or 3?
70/2E and 71/2B til 9-71 had veriable speed then 3-sp after that.
Bet RA 72 is not correct either.
Stating in 73 all -3speeds had a plastic cover
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: What's different 70-71 vs 72-74 Wiper motors [Re: moparmarks] #1142758
12/23/11 10:36 PM
12/23/11 10:36 PM
moparmarks Offline
moparmarks  Offline
Yep just checked. Their 72 3-spd is a 73 and up.
71 didn't come up.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What's different 70-71 vs 72-74 Wiper motors [Re: moparmarks] #1142759
12/23/11 10:38 PM
12/23/11 10:38 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
two speed
Re: What's different 70-71 vs 72-74 Wiper motors [Re: magiccuda] #1142760
12/23/11 10:42 PM
12/23/11 10:42 PM
moparmarks Offline
moparmarks  Offline
They changed in 6-72. Not sure what changed though
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What's different 70-71 vs 72-74 Wiper motors [Re: moparmarks] #1142761
12/24/11 12:28 AM
12/24/11 12:28 AM
BDW Offline OP
BDW  Offline OP
I'm just looking for the cheapie 2-speed for a 70.
They all have the same hoods, so the lower park position doesn't make sense.
I'd guess the wiring harness is different.
Hoping someone has gone through this already.
Re: What's different 70-71 vs 72-74 Wiper motors [Re: moparmarks] #1142762
12/24/11 02:25 PM
12/24/11 02:25 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the diff between 3 speeds and variable is actually at the switch not really at the motor
Dunno what you mean about "plastic" cover
the diff between earliers and lates at least on 3/var speeds is lates have a "tower" on cap ( maybe this is what you meant about the plastic cover ? ) for the parking and turn off switch, and earliers are flat
Re: What's different 70-71 vs 72-74 Wiper motors [Re: NachoRT74] #1142763
12/24/11 02:35 PM
12/24/11 02:35 PM
moparmarks Offline
moparmarks  Offline
Hi Nacho
The motor in the upper pic has the plastic cover over the wire connections, thats the 73-up style.
Lower one has resin thats the 72-down sytle.
Heres the early 72B/E 534 V-spd.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #1142764
12/24/11 02:39 PM
12/24/11 02:39 PM
moparmarks Offline
moparmarks  Offline
You need a 929 2-sp which fits 70/1E, 71B 69/71C
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What's different 70-71 vs 72-74 Wiper motors [Re: moparmarks] #1142765
12/24/11 02:51 PM
12/24/11 02:51 PM
BDW Offline OP
BDW  Offline OP
Ok, we're getting closer. In the 2 pics above, the connector looks the same.
So why (or what needs to be done) can't I use a 73 model.
I can buy it from RockAuto for $40.
70 version is NOT avaliable. Hoping to not pay $300 to have it rebuilt.
Re: What's different 70-71 vs 72-74 Wiper motors [Re: moparmarks] #1142766
12/24/11 03:24 PM
12/24/11 03:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Hi Nacho
Hi Mark!
yep I guessed that was what you meant
HOWEVER I mounted a 72 3/var speeds on my 74, and it has also the plastic cap/tower. Maybe a mid 72 year change ?. I can grab the PN around
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #1142767
12/24/11 03:25 PM
12/24/11 03:25 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
HONESTLY ? I think all 70/74 E and 71/74 B motors are TOTALLY interchangeable. Diff stuff is a correctness deal
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #1142768
12/24/11 03:31 PM
12/24/11 03:31 PM
Central TX
roe Offline
roe  Offline
Central TX
Post an ad in the parts wanted section. I ran into this when my wiper motor quit on me. I never did get a straight answer on how to adapt the readily available wiper motor to work on my car. So I put a parts wanted ad and recieved responses really quickly.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #1142769
12/24/11 04:53 PM
12/24/11 04:53 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Didn't 72 use the clip for the wiper arm and the 73 use a nut ? My 72 Challenger 3 spd motor uses the clip and my 73 Roadrunner 3 spd motor but I'm pretty sure it uses a nut for the wiper arm.
Re: What's different 70-71 vs 72-74 Wiper motors [Re: 73rrak] #1142770
12/24/11 05:02 PM
12/24/11 05:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I was thinking on that as a posibility HOWEVER, Once I got a NOS repairing kit and on instruction sheet never said something about the year, and included a big list of wiper motor PNs including earliers. The kit included the threated shaft.
I would say really the clip its at CRANK side of main linkage and not to the motor shaft side
Re: What's different 70-71 vs 72-74 Wiper motors [Re: NachoRT74] #1142771
12/25/11 04:59 PM
12/25/11 04:59 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
The 71 and the 72 are not a straight interchange. The crank to wiper lingakge are a little different and if you use a 72 motor on a 71 (or vice versa) it won't bolt up to the crank arm. The 71 is the last year for the red epoxy on the front wire, the 72 is left bare (I think they put a plastic cover after that). The direct cowl boltup is the same, and the wire harness is the same. Two speed switches will not work on a var/3 speed, or vice versa.
Mo Mopar was horrible on the interchange between years in the 70's. I'm sure it had to do with sub contractor suppliers.
Re: What's different 70-71 vs 72-74 Wiper motors [Re: DANA60] #1142772
12/26/11 02:12 AM
12/26/11 02:12 AM
moparmarks Offline
moparmarks  Offline
Even a different crank between the two 72B/E V-spd #534 and the 3-spd #624.
Also both these 72 motors had resin or red epoxy.
Again 73 was the first year for the plastic cover.
70-2 linkage has brass bushings and the big round clips.
73-up had push in nylon bushings.
Very little will interchange or work between 72-down and 73-up.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What's different 70-71 vs 72-74 Wiper motors [Re: DANA60] #1142773
12/30/11 11:58 AM
12/30/11 11:58 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
PN application:
Part#/Stamp# Year-Yr Body Speed Remarks
2525629 1964-66 A VARIABLE
2525270 1964-65 B SINGLE
2580915 1967 B VARIABLE
2584975 1965 C VARIABLE
2586988 1966-67 C 2/3 SPEED
2587697 1968 B 3-SPEED LATE
2770090 1968 C 2-SPEED
2770090 1969-71 A 2-SPEED
2770090 1969-70 B 2-SPEED
2770147 1966-67 AB VARIABLE WHITE SW PLATE PARTS
2808767 1967 AB VARIABLE LATE ALUM/BLACK PARTS
2808767 1968 B 3-SPEED EARLY ALUM/BLACK PARTS
2808801 1966 B VARIABLE WHITE SW PLATE PARTS
2808801 1967 AB VARIABLE WHITE SW PLATE PARTS
2822252 1968 AB 2-SPEED
2822962 1967-68 AB VARIABLE LATE ALUM/BLACK
2822963 1966-67 AB VARIABLE EARLY WHITE SW PLATE
2822965 1967 B VARIABLE
2889982 1968 B 3-SPEED LATE PARTS
2926919 1969-71 C 3-SPEED PCDY
2926929 1969-71 C 2-SPEED
2926929 1970-71 E 2-SPEED
2926929 1971 B 2-SPEED
2983033 1969 B 3-SPEED EARLY
2983116 1969-71 A VARIABLE
2983116 1969 B 3-SPEED LATE
2983116 1970 B 3-SPEED
3004112 1968 C 2-SPEED
3004114 1968 A VARIABLE
3004114 1968 B 3-SPEED LATE
3431077 1970-71 E VARIABLE
3431077 1971 B VARIABLE
3431531 1972 A 2-SPEED UP TO 6/5/72
3431532 1972 A VAR-3SP
3431533 1972 BCE 2-SPEED UP TO 6/5/72
3431534 1972 BE VAR-3SP UP TO 9/1/71
3431535 1972 C VAR-3SP
3431605 1972 A 2-SPEED AFTER 6/5/72
3431605 1973 A 2-SPEED UP TO 2/1/73
3431606 1972 BCE 2-SPEED AFTER 6/5/72
3431606 1973 BCE 2-SPEED UP TO 2/1/73
3431624 1972 BE VARI-3SPD AFTER 9/1/71 BLACK CAP
3431665 1973 BE VARI-3SPD
3431666 1973 C VARI-3SPD
3431718 1973 BCE 2-SPEED AFTER 2/1/73
3431730 1973-74 A 2-SPEED AFTER 2/1/73
3431780 1974 C 3-SPEED
3431790 1974 BCE 2-SPEED
3431905 1974 A 3-SPEED
3431906 1974 BE 3-SPEED
3620877 1973 A VARI-3SPD
( I thought this file was missed around http://web.archive.org/web/20050117073829/http://www.wiperman.homestead.com/Motor_part_numbers.html )
Re: What's different 70-71 vs 72-74 Wiper motors [Re: NachoRT74] #1142774
12/30/11 12:09 PM
12/30/11 12:09 PM
moparmarks Offline
moparmarks  Offline
The 3431624 is a 3-sp and does not have the black cap.
Heres the one that came on one of my later 72's. Have had several more just like it.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
