B-body front end rebuild kit - Where to go?
#114248
09/02/08 08:56 PM
09/02/08 08:56 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
front end needs gone through on my 67 Satellite. Guess I'll take a stab at doing it myself. Any reason to NOT buy this kit? Anyone here used this kit before? Is there any difference from one to another? (I'm new to front end work, but willing to learn) http://cgi.ebay.com/ebaymotors/ws/eBayIS...bayphotohostingBudget is the main issue here. This is a weekend street / strip car & just needs a stock front end under it.
Re: B-body front end rebuild kit - Where to go?
[Re: StealthWedge67]
#114249
09/02/08 09:54 PM
09/02/08 09:54 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Hmmmm...
The kit looks complete, but I wonder.... Have you priced-out the same parts at your local autoparts store?
On my '71 Charger, I replaced the front-end parts in 2000. I don't recall the total parts bill as being that high ($254 plus $22 for shipping) but then again, it was 7-8 years ago.
It was do-able, but there were challenges, like getting the torsion-bars dislodged (they make a good clamp-tool to remove 'em with a sledge-hammer) and pressing the lower-control-arm bushings out of the arms was no picnic either.
A giant pipe-wrench came in handy for unscrewing the upper ball-joints (though some are "press-In" type, mine were threaded.)
I media-blasted all the re-usable parts and painted/repainted.
A Factory-Service-Manual comes in handy too.
[Re: Brute]
#114253
09/03/08 07:34 AM
09/03/08 07:34 AM
Posts: 1,443 Maryland
Dads426
Maryland
On our Challenger I bought a kit. Still had to buy a separate pitman arm. On the 64, I bought everything from Advance Auto and Rock Auto depending on who had the lowest price. It takes longer to compare prics, but you can choose which brand to buy. Came out cheaper buying it piecemeal. Advance had a deal where if you buy more than $50 and shipping weight is under 20 lbs, shipping is free. For Rock Auto, search this site for a 5% disount code (cuts shipping costs).
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
#114254
09/03/08 03:13 PM
09/03/08 03:13 PM
Posts: 2,592 None
71rm23
None
I thought there was a posting here a while ago about Moog. There were the pros and cons of using Moog. If I remember, there made in China, Japan and the fitting wasn't as good as some others One of the companies makes everything here in the USA. Not trying to P.O anyone but if this is the case, I'd rather have a product that fits good as well. Just keep an open mind
[Re: 71rm23]
#114257
09/03/08 05:26 PM
09/03/08 05:26 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Moog is the best you can get.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Dads426]
#114258
09/03/08 08:48 PM
09/03/08 08:48 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
When I recently did the front end on my car, I got Summit Racing to pricematch Rockauto on the Moog components, and then saved a ton on money with Summits flat shipping rate.
Just figure out all the pieces you need from Rockautos catalog and reference back and forth. 30 mins of searched saved me almost $100.
Sweeeeet! I'll have to remember that!
[Re: 71rm23]
#114261
09/07/08 01:21 AM
09/07/08 01:21 AM
StealthWedge67
Puyallup, WA
I can only assume that the kit I linked in the original post comes with everything you need. I want good components, but at the same time, this is no Porsche, no matter what we do. I really just want it to be solid rolling down the road, and something I feel confident in @ 100 MPH @ the strip.
[Re: 71rm23]
#114266
10/02/08 08:25 PM
10/02/08 08:25 PM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
I see that most replies are for Moog. Here's a question now: Is Moog as good or the same for Spicer as well? I don't see many good post for poly. I dont want to put in parts from Japan or China in my Mopar
Does Moog have a low end and a high end part like spicer??
[Re: BADBEE]
#114268
10/03/08 03:49 AM
10/03/08 03:49 AM
Posts: 2,592 None
71rm23
None
It would be nice to get the complete Moog parts for this job and post it in the tech archives. I am looking to do this same jobe very soon and it would be handy to have those numbers to contact Summit.
[Re: Brute]
#114270
10/03/08 10:57 AM
10/03/08 10:57 AM
Posts: 2,592 None
71rm23
None
If anyone doesn't do this by tomorrow night I can post up any numbers out of the moog catalog that you need. One problem I have found working in the auto parts industry is that no matter what the box says sometimes you will run across reboxed parts from changeovers or simply from shady individuals who swap parts and return the cheap parts in the expensive part's box. That why I ordered all of my Moog front end parts and made sure to check each part to make sure it was really a moog part and not some no name rebox.
How do you know if it is reboxed or not? Does Moog put the P/N's on the parts? Also, Is moog better than Spicer? I would like the P/N's for Moog as well, for my '71 RR...THANX
