Re: 5.7 hemi swap won't start?
[Re: 69rrconvert]
#1137258
12/16/11 09:14 PM
12/16/11 09:14 PM
Posts: 8,489 Candler,NC / Myrtle Beach, SC
JDMopar
I had the same issue with my 5.7 swap. It turned out to be the fuel injectors were gummed up from sitting. My 5.7 came out of a salvage yard and had sat for awhile before I tried to get it running. I pulled the injectors and placed them in a bowl filled with paint reducer and let it sit overnite. The next morning the reducer was brown in color. Reinstalled the injectors and fired right up
I'll remember that! I've got a 2006 5.7 Hemi with 6000 miles on it, that's been sitting since 2006. I roll it over with a breaker bar, but it will be a year or 2 before it runs again in my 70 Duster. Original poster...please let us know what you find that's keeping it from running if this isn't it.
[Re: 69rrconvert]
#1137259
12/16/11 10:42 PM
12/16/11 10:42 PM
Posts: 71 Memphis, MO
xpsyclonex2002
Memphis, MO
Interesting. I never thought of that.
[Re: xpsyclonex2002]
#1137261
12/22/11 02:34 AM
12/22/11 02:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok. Soaked the injectors in acetone. Still no joy. Anyone else got any ideas?
Like was asked... do you have fuel pressure at the rail
[Re: MR_P_BODY]
#1137262
12/22/11 02:49 AM
12/22/11 02:49 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
As far as cleaning injectors... http://oldfuelinjection.com/?p=82Beyond that as mentioned do you have pressure in the rail... 12 volts to the injectors, pulsed ground signal. Do you have a noid light to test the signal?
[Re: MR_P_BODY]
#1137264
12/22/11 01:57 PM
12/22/11 01:57 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
That is why I had asked...when I did my LS1 swap, I checked for fuel pressure before even trying to fire it. (I have a gauge right on the aeromotive regulator though so makes it easy)
Once you verify you have proper fuel pressure then start working your way from there with injectors getting a signal and working, etc.
#1137268
12/25/11 01:56 PM
12/25/11 01:56 PM
xpsyclonex2002
Memphis, MO
I'm running the 2005 computer that came with the motor. I'm not sure what you mean by "require you to run directly to the battery"? I am using a harness from Street and Performance that was made just for this swap.
bump
#1137269
12/25/11 02:11 PM
12/25/11 02:11 PM
MR_P_BODY
OK Guys, I have had some time to work on this. Putting a NOID test on it shows that I have no signal going to any of the injectors. I put a fuel gauge at the rail. I can't get it to run so I am only able to read it with the key turned. I can hear the fuel pump running for a second or two at most then it stops. The reading I get is at around 10PSI! I cut the wire coming of the starter relay and hard wired it directly to the battery. That gives me nearly 60 psi at the rail! I know I'm supposed to have about 55psi to run the motor. Why am I not getting it unless I come directly off the battery?
When you turn the key to the on position you get a 3 second pump run time... you only get 3 key on pump runs then the engine has to turn over so it sees that the engine is tuning(thinks its running)... as to no power to the injectors... that can be multiple things
#1137270
12/25/11 02:12 PM
12/25/11 02:12 PM
OzHemi
Garden Grove, CA
The pump running just for a second and shutting off when you turn the key to on sounds normal (that is how most cars seem to be) should just prime the system them when you turn the key to start it should and then running it will run the pump as normal. If you only have 10 psi it does sound like there is an issue ? How does your fuel pump get power normally, is it through the loom getting a trigger from the PCM ? I've never done a Hemi, but with the LSx setups and using factory PCMs you have to make sure you have them burned to remove the anti-theft stuff that turns stuff off after cranking from memory.
[Re: MR_P_BODY]
#1137272
12/25/11 06:58 PM
12/25/11 06:58 PM
xpsyclonex2002
Memphis, MO
Can you guys give me a quick rundown of the most common causes of the injectors not getting power and how to test for them? I am no mechanic, just a guy who is crazy enough to tackle a project like this with no help except the forums.
#1137285
01/12/12 07:43 PM
01/12/12 07:43 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
For an 05 Truck only one of those codes come up? What is the p# of the PCM??? It sounds like you have a wiring issue if supplying battery power to the fuel pump increases fuel psi from 10 to 55psi. I would double the wiring connections you had to make. BTW A street and performance harness is most likely not built by s&p. You might want to try hotwireauto. The Squires most likely built the harness. Just my If you want PM me your cell, and I will trouble shoot over the phone. Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
#1137287
01/12/12 09:14 PM
01/12/12 09:14 PM
wldtm
Dayton, Ohio
that dropped my confidence a little bit now. part#???
PM for details
