Page 5 of 8 1 2 3 4 5 6 7 8
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135484
12/18/11 04:41 PM
12/18/11 04:41 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What custom wheel choices are there , or do they all look like 4x4 wheels ?
Can I use wheels off a late model base Dodge van, the ones that are kinda like rally wheels ?
I think I know where I can get a set of those , IIRC they are 16's .. right ?
I know the rims you're talking about, I think they are the steel rims on the 94-01 1500's as well. To get those to work, your need to machine the center register from 3" to 3.5". Any machine shop with a lathe with at least a 16" swing could do it and it shouldn't be to much $ wise. I had an 89 shortbox that I put a set on and that's what I had to do. They fit great on the front but on the back they get really close to the box, I guess they have less offset that the stock 15" rims. I had 245/75/16 tires and they cleared by about 3/4", if I cornered to hard they would rub, not enough to do any damage to the tire or even hear or notice when you're driving but you could see it. with a low profile tire, you would have even more clearance and probably be fine.
As for aftermarket rims, there should be a ton, as the late 60's to 96 Ford half tons had the same bolt pattern and the same 3.5" center register. There seems to be no shortage of aftermarket rims on those things.
And just to clarify, what exactly changed on the 81-84 rotors? Is it just the machined diameter on the inside of the rotor where the bearing race presses into?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: WO23Coronet] #1135485
12/18/11 09:58 PM
12/18/11 09:58 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Uhhhh .. as far as I know, they were only on just the vans ?
My brother has a old retired work van and it had them so I called him to see if they could be had
He put them on his 91 4x4 Dodge
so, I guess that means they fit ?
Maybe after Christmas I go digging around a junk yard to look for a set
I took the little guy for about a 75 mile road trip today, it just truely is a sweet little truck
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135486
12/18/11 10:57 PM
12/18/11 10:57 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the hubs on the 5.5 rotors use a larger diameter inner bearing.
I am truckless..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135487
12/20/11 01:30 AM
12/20/11 01:30 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Well, I guess the vans are different that the 1500's, that's what I had to do to put 94-01 rims on my 89
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: WO23Coronet] #1135488
12/20/11 02:47 AM
12/20/11 02:47 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Vans still had the larger hub so the van wheels Will fit the pre 94 trucks without a problem. They also use the same control arm till 97 or so.
My cousin had a 96 or so shorty van and my mom had some 94 up 1500 rims for sale and when we went to put them on to see how they looked they wouldnt clear the hub. I dont think it matters if he finds wheels its already listed forsale
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 76dodgeboy] #1135489
12/20/11 02:51 AM
12/20/11 02:51 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Its for sale, doesn't mean it will sell
I plan to keep it but, never know ?
Here it is less all the autozone stuff
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 76dodgeboy] #1135490
12/20/11 03:03 AM
12/20/11 03:03 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Pretty sure he means these
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 76dodgeboy] #1135491
12/20/11 03:16 AM
12/20/11 03:16 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The lowered version
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 76dodgeboy] #1135492
12/20/11 03:20 AM
12/20/11 03:20 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
closer but, I have seen them with chrome rings and center caps
I'll see if I can locate any
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 76dodgeboy] #1135493
12/20/11 03:21 AM
12/20/11 03:21 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The lowered version
Don't think I'll drop it down that far
Just enough to have the tire opening and tire top meet
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135494
12/20/11 03:23 AM
12/20/11 03:23 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I haven't deleted the sheep head off the hood but, its coming soon
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135495
12/20/11 03:36 AM
12/20/11 03:36 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I agree,, the 8 1/4/8 3/8 axle shafts will interchange.
My 88 was a 318 NP435 shorty.
I thought it had a 8 1/4 till I had a counter clown buddy at a dealer run the numbers.
It came out to be a factory original equiped 9 1/4.
That 9 1/4 diff that I have was going into my 87 RC till it met its demise.
I am truckless..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135496
12/20/11 04:29 AM
12/20/11 04:29 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
I have searched for a Squarebody Dodge 81-93 Shortbox for years , it had to be nice..
This one is really, really original and CLEAN !
thats a cool ute
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: scratchnfotraction] #1135497
12/20/11 09:54 PM
12/20/11 09:54 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Can anyone provide me with proper part numbers so I can find / order have in stock when I am ready to swap the bolt pattern change over
for
front rotors, bearings, etc ..everything for the front I need
Part number and contact info for the leaf spring hanger part I'll need to lower the rear of the truck ?
I'll also need to locate rear axles, etc.
for those that have done that , if you can help me with any parts I will need so I don't have to make several trips to salvage yard and or parts store
my nearest napa is about 22 miles away , the rest are like banging your head on the wall
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135498
12/20/11 11:05 PM
12/20/11 11:05 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Are you thinking about Chrysler road wheels
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: hp383] #1135499
12/20/11 11:47 PM
12/20/11 11:47 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Yep, they made on 1500 series trucks and light duty vans, wheels that look a lot like that but they are 5 on 5 1/2 bolt pattern and the center cap has a goat head on it
I seen a 96ish truck today with a set but, couldn't catch him to take a pic
here is what I did catch
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: hp383] #1135500
12/20/11 11:49 PM
12/20/11 11:49 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
ROTORS
Raybestos #7034
Bendix #1072
BEARINGS
BR 16 Outers
BR 17 Inners
I am truckless..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 340SHORTY] #1135501
12/21/11 12:24 AM
12/21/11 12:24 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
That's a nice little truck. I'd love to build something like that too. Slammed, no moldings, 70s front bumper, pan in the rear, 91-93 grille, monotone, cowl hood and some Weld Wheels. There is one for sale around here. Think it's an 84, already has a 440 in it. Could probably get it for around 2k and it's pretty decent. Just have to keep telling myself, NO MORE VEHICLES right now.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: pinkduster] #1135502
12/21/11 12:43 AM
12/21/11 12:43 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I had wondered where you were ?
I forgot to ask ( I think ? ) will a late model Ramcharger rear bumper bolt on ?
I'll want to get that big step bumper off
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135503
12/21/11 12:59 AM
12/21/11 12:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
6 bolts and the license plate wire
a rollpan would look better
I am truckless..
