Re: Do I have to take care about 2nd piston ring end gap?
[Re: nomore65BelvJim]
#1134443
12/16/11 06:36 PM
12/16/11 06:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A lot of engine builders now are running the second ring gap at a couple thou larger than the top ring gap to reduce ring flutter... if it got past the top ring you dont want to hold it back and cause any flutter to both rings.... this is what I've been doing for some time now
that makes sense
have you noticed any differences since you started doing this?
I cant say for fact due to I dont dyno my engines and usually it isnt quite the same set up
I was thinking more of a difference in the wear and tear on the rings and grooves/lands.
you shouldnt see any difference in the land, its still riding on a flat surface(ring riding on lands)
[Re: MR_P_BODY]
#1134444
12/17/11 01:39 AM
12/17/11 01:39 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
wow, lot of diff info coming and going.
I think will go 0.017" as the basic formula and paying attention to silvolite website saying their pistons doesn't require bigger or extra clearence at the second ring... just going to the basic
[Re: NachoRT74]
#1134445
12/17/11 01:45 AM
12/17/11 01:45 AM
MR_P_BODY
have at it... stock specs will work
[Re: MR_P_BODY]
#1134446
12/18/11 01:28 AM
12/18/11 01:28 AM
NachoRT74
Valencia, España
at the end, went 0.018". Some rings maybe a little bit larger ( 19 maybe? ) accidentally
